headlights -- reduce the delay before turning off?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by unterhausen, Jan 8, 2014.
  1. unterhausen
    unterhausen Junior Member
    64
    State College, PA
    My search didn't come up with this, I'm sure this is a dupe thread, sorry
    On the Gen II, when you turned off the car and opened the driver's side door, the headlights turned off. On our Gen III, I have never really been willing to wait, and just turn the headlights off manually. Is there a way to change it so it works like a Gen II?
  2. fuzzy1
    10,698
    Yes, the GenIII headlight delay can be customized to zero. Choices are 0 / 30 / 60 / 90 seconds.
    Methods may vary by year/model/trim, what do you have? My 2012-Three can be changed through the Display Audio system, or the Nav system, or by the dealer. (Owners Manual, Sec 6.2 Customization, p. 593). My 2010-II could be customized only by the dealership.
  3. genetiix
    genetiix Member
    123
    49
    San Jose, CA
    For my 2012, the timing could be controlled in the settings from the head unit while parked. Have you tried there?
  4. unterhausen
    64
    State College, PA
    I did try the mfd, but I might not have met all the conditions needed to see the menu
  5. fuzzy1
    10,698
    Depending on the particular model, you may not be able to do it without special electronic tools.
    Please let us know what year, model (Liftback / v / c), and trim level you have. If was Nav is an option, not standard for that trim level, then mention it too.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Dealer can always change it. Any other method would require knowing more than "gen 3"
  7. unterhausen
    64
    State College, PA
    it's a 2010V hatchback with the technology package and the nav package
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  9. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Dealer, or anybody else with the proper tools...
    In my case, I was too lazy to go to the dealer just for that tweak, so I think it was cwerdna who took care of me at a Prius meetup in the area.
  10. unterhausen
    64
    State College, PA
    I suppose I'll have to ask the dealer when I take it there next time. Hopefully they know what I'm talking about
  11. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Does anyone know how to make these adjustments with a scangauge? I know the seatbelt reminder and reverse beep can be adjusted with the SGII.
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  13. burstaneurysm
    469
    144
    Chicago, IL
    Yeah, I was just looking at the same doc. Bummer.
  14. macman408
    1,179
    368
    Yeah, the ScanGauge can't do the headlight one because it uses a different data format on the CAN bus. A fancier device might be able to, though.
