Headlights too high?
Discussion in 'Gen 4 Prius Main Forum' started by BoltonJoe, Feb 7, 2017.
  1. BoltonJoe
    BoltonJoe Junior Member
    55
    Massachusetts
    Interestingly enough, I have not had any more oncoming drivers flash their lights at me, but I will ask the dealer to lower the low-beams slightly at my first maintenance visit. I love this car so far--although I've only had one fill-up since buying the car.
    Joe
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    Is your car a 2016 or 2017 Gen 4? I have only seen reports of the 2016 cars getting flashed excessively.
  3. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I get flashed a quite a bit, especially on my own road I live on (2 way semi busy street) with a 2016. Its not too bad once i get on a major median road. Interestingly enough, one day I got flashed by another prius 2016 or 17 (saw the tail lights in the rear view mirror). The other prii's lights were bright but I was pretty sure he wasn't running high beams so I didn't flash him.
    RCO likes this.
  4. Scuderia Priusi
    96
    111
    PacNW
    IIRC, I had to lower my US-spec 2016 4 headlights about 3 to 4 'flats' of the adjuster bolt-screws (a little more than a half turn). Problem solved. I've had zero flashing from on-coming traffic since.
    BTW, 10 months in, and I'm still lovin' this car. (y)
    krmcg likes this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps the other Prius was just saying "Hi.". This was discussed on PC back along, but most folks on stateside felt that we not a popular idea, but there weren't many Gen 4s on the road back then. Who knows, it may catch on among Prii enthusiasts... if not Uberistas. ;)
  6. robsnyder20
    378
    302
    SW Florida USA
    Good point but I doubt he could see me as it was at 4AM
    RCO likes this.
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    Some people flash the same model car not necessarily because of the people inside.
    My first reaction was they would have seen you if your headlights were on. :D
    #27 Prodigyplace, Feb 17, 2017
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hmm! Maybe he could recognise your lamp configuration and thought, hey, that's another Prius. Or was wearing NVGs.
  9. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    2018's on the Prius C are aimed too high as well. I bought the car 3 days ago and I already got flashed about 5 times by the incoming traffic. I noticed they were too high when I test drove the vehicle.
  10. Frederickdawg
    Frederickdawg Active Member
    596
    337
    Florida Unfortunately
    I just turn the dial on the stalk and it lowers the led headlight output. Forgot which setting, but you can check it in front of a white wall. One setting is extremely bright and the other is slightly dimmer. I'm not referring to high beam either.
    SM-N960U1 ?
  11. Prodigyplace
    12,712
    11,848
    Central Virginia
    You are referring to daytime running lights that do not light the tail lights.
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    The dealer needs to fix that under warranty. I think checking is part of the pre-delivery inspection.
  13. Frederickdawg
    596
    337
    That's what I first thought it was. Its something that does light up the tail light. I checked the back lights were also on.
    SM-N960U1 ?
    Prodigyplace likes this.
  14. Prodigyplace
    12,712
    11,848
    Central Virginia
    DRL + parking lights?
  15. Frederickdawg
    596
    337
    Possibly. I also recall the amber markers are also on when the headlights are on with this setting. But generally speaking at night the setting has a lower led headlight output, yet still effective and also comfortable for other road users.
    SM-N960U1 ?
  16. Prodigyplace
    12,712
    11,848
    Central Virginia
    Not sure about legality though. I know they changed the headlights for 2017 to reduce the glare in test results.
  17. Frederickdawg
    596
    337
    I remember back in the late 90s and early 2000s when BMW and some others introduced xenon lights . Many folks also thought they were too bright as they were not used to the technology at the time. Thus owners got a lot of other road users flashing their headlights at them.
    SM-N960U1 ?
    kithmo likes this.
  18. Prodigyplace
    12,712
    11,848
    Central Virginia
    2016 test
    2017 test
  19. fuzzy1
    10,706
    That is what happens on both my 2012 Prius Liftback and on my Subaru, when turned down a single notch. It takes a turndown of 2 notches to get DRL without parking lights. Of course, neither of these vehicles have LED headlights, so it is not a strictly comparable situation.
    I suspect it is illegal in nighttime conditions requiring headlights, but legal in daylight when DRLs are acceptable. DRLs simply don't have a legal low-beam pattern.
  20. Mendel Leisk
    42,343
    Around here seeing more-and-more "ghost" cars, not the traditional undercover cops, rather someone driving at night with just their daytime running lights, no other lights. Kinda maddening. I can't understand why they wouldn't clue in, notice their dash is dark, but apparently some of the latest model cars, you always see dash lights??
    alanclarkeau and fuzzy1 like this.
