HEADLIGHTS
Discussion in 'Gen 2 Prius Technical Discussion' started by RICH MOFFO, Oct 30, 2024.
  1. RICH MOFFO
    RICH MOFFO Junior Member
    Tiltonsville, Ohio
    my headlight on the driver side keeps going off . when I turn light switch off then on it comes back on for a few seconds. it just keeps doing that and wont stay on. I put in new bulb but still does the same thing. Any suggestions. Thanks in advance.
  2. ETC(SS)
    6,958
    New bulbs....
    OEM??
    Walmart?
    Stealer?
    I do not mean to offend but there are people who try to cosplay led/HID bulbs.
    Accidents?
    The first thing I would do is to check voltage at the socket, to make sure that fender-bender 10 years ago didn't shake a wire loose.
    Then?
    I'd look at the [sic] 'bulb.'
    They're DIFFERENT for LED(your original bulbs are almost certainly NOT THAT!), HID (Perhaps available in '09 G2s,) and the original old-school filament bulbs.
    More info, plz.
    Or?
    2009 Prius Headlight Bulbs | PriusChat
    Not all HID Bulbs are created equal | Page 2 | PriusChat
    You can always swap left for right and see if the symptoms change - presumming you replaced both 'bulbs' at the same time - and WHY would you NOT DO this since you've already got the hood open?
