Headliner pills too easily
Discussion in 'Prime Main Forum (2017-2022)' started by Heedunk, Jul 19, 2021.
  1. Heedunk
    Heedunk Junior Member
    61
    23
    Bay Area
    2020 Prius Prime
    I wired a dual channel dashcam under the headliner trim from the windshield to the hatch. I guess I was a bit rough with the wiring as now I have pilling where I routed around the A and B pillars. I used a razorblade and a pilling shaver to remove the excess pilling, and while it looks better, you can still see where the fabric is not the same and is "balding". I never had this problem in other cars.
  2. Mendel Leisk
    42,298
    Someone very recently reported here: tried to clean a mechanics greasy handprint off the headliner, using a spray can cleaner with integrated plastic bristle brush applicator. It shredded on the first stroke or two, ended up with dangling threads of material.
    Salamander_King likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,569
    2,602
    Taylors, SC
    Pilling occurs with high tensile strength fibers. Natural fibers like cotton and most wools are low tensile strength, break and wear off.
    The only answer is not to scrub on the headliner as I did at one time. Blotting is the only viable method to avoid "pilling" the headliner.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    The felt-like material used for lining the cargo deck, side, and back of the rear seats are equally prone to pilling. Extremely hard to clean the surface if it gets soiled. Small debris of leaves and dust get stuck in the fibers and even the strong shop vac can not remove them. I don't have any way to cover the headliner but I am totally covering the cargo area with a custom-made canvas liner.
    Georgina Rudkus likes this.
  5. Heedunk
    61
    23
    Bay Area
    2020 Prius Prime
    I am afraid to install LED map lights because of the difficulty in removing the map light unit could resulting in pilling of the headliner.
  6. dtsexpert
    dtsexpert Member
    180
    83
    San Francisco
    For map lights, you need a pry tool to remove
    the cover. It is not hard at all.
    $5 Pry tools from Amazon
    bisco and Washingtonian like this.
  7. Trollbait
    12,814
    Harbor freight also has them cheap.
  8. Heedunk
    61
    23
    Bay Area
    2020 Prius Prime
    Thanks. I installed the LED lights and was extra careful with the headliner. With caution, it was quite easy.
  9. JMalmsteen
    JMalmsteen I love my Prius!
    287
    266
    Long Island, NY/Lancaster, PA
    I'm not a fan of the headliner material. It seems cheap. It has a weird linen like texture. Hopefully, Toyota will update it to something of higher quality that is less prone to stains.
