Heads up: looks like safety-recalled brake accumulators on eBay
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ChapmanF, Nov 9, 2017.
  1. Mendel Leisk
    41,459
    That's EXACTLY what I was thinking of: same hat, same expression. Speaking of avatars: @bisco has one, wonders never cease. (y)
    Patrick Wong, m.wynn, bisco and 2 others like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Peer pressure is amazing sometimes (y).
    sfv41901, m.wynn, bisco and 2 others like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Probably found a kid to show him how. :LOL:
    m.wynn, bisco and Raytheeagle like this.
  4. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Believe his son and his iPhone ;).
    Whatever it takes(y).
    m.wynn, bisco and jerrymildred like this.
  5. bisco
    51,937
    ray can be very persuasive. and persistent.:cool:
  6. Patrick Wong
    18,210
    6,510
    Am I mistaken or is bisco's garage door about to slam down on his Prius?? :cool:
    m.wynn, Mendel Leisk and Raytheeagle like this.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Probably an optical illusion as he was trying to not capture the license plates.
    jerrymildred likes this.
  8. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    What's the best way to check the part number on the yellow label while the part is installed in the car? Some kind of a mirror on a stick? Stick your phone underneath and try and take a pic?
  9. Mendel Leisk
    41,459
    Selfie stick?
  10. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    I don't think there's room to get one in there. From the engine bay I can barely see the corner of the yellow sticker. I'm guessing you have to disassemble the car, yank the part to get the number off it then order it but I don't know any mechanics that want a immobile car sitting around for a few days to a week waiting for a part.
    Can Toyota look up part numbers by the VIN?
    Edit: went to onlinetoyotaparts.com and plugged in my VIN then browsed to ABS section and found the diagram for the accumulator, the part # they gave was 4707047060. I've seen some ebay auctions for a 2010 Prius with part 4707047050, off by 10 digits. I've also seen some on ebay with the part number that onlientoyotaparts.com provided.
    #30 Jkan2001, Aug 14, 2018
  11. Mendel Leisk
    41,459
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
  13. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Yep bought this one, hope I can grab the actual part # and match it.
    Raytheeagle likes this.
  14. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Is the part # on the yellow label or elsewhere on the part?
  15. ChapmanF
    18,206
    I wouldn't fret a whole lot about the accumulator part number, as long as it's not one of the recalled ones.
    There was a recent thread about obsessively matching actuator part numbers, which might make sense especially in Gen 3, where the actuator is quite a sophisticated part and includes a computer, and the computer has firmware, and the firmware has versions.
    The accumulator, though, is an electric pump that pushes brake fluid into a bottle. As long as it does push the fluid into the bottle, and the fluid stays in the bottle until you use it (and the nitrogen in the bottle stays in the bottle, period), it is doing what an accumulator does. :)
    -Chap
  16. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Thanks for the info, I thought there was some talk around here about people matching the exact part numbers of the accumulators to match the one in the car to avoid programming but as you pointed out that's the actuator. At this point I think I'm going to try replacing the accumulator first since that seems to be the common culprit with C1391 error codes.
  17. socc705
    socc705 New Member
    Sarasota, FL
    I have some good news. I sent a letter to Toyota corporate, and with all the complaints they’ve been receiving, they decided to update the Toyota Safety Bulliten to include the additional Prius’ that weren’t previously covered in the C1391 or brake issue. So my $4500 repair bill ended up being $0! I suggest everyone to take their Prius to Toyota if they hadn’t been covered before, you will now. Cheers!
    Jkan2001 and jerrymildred like this.
  18. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Wow, that's big news. I was about to start repairing mine myself. Do you have this in writing? If so can you share?
  19. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    I was able to confirm there is indeed a new customer support program for 2010 prius that were outside the original recall VIN range. Just take your car to a dealer and they will diagnose and fix it free if that is indeed the issue.
    Dropping mine off tomorrow 7 am
    #39 Jkan2001, Aug 17, 2018
  20. ChapmanF
    18,206
    Good news! Anybody find a TSB or campaign number for that?
    -Chap
