Headunit Suggestion
Discussion in 'Gen 3 Prius Audio and Electronics' started by TomasV, Jul 29, 2018.
  1. TomasV
    TomasV Junior Member
    52
    Haddon Heights, NJ
    Hello all,
    Looking to replace the factory headunit with a new one in a 2011 Prius II. Currently it has a headunit without touchscreen but with JBL audio. Is there a headunit that would be a direct swap and would include a backup camera? I've been looking around and I've seen a couple of nice one, but they were not an easy swap. Don't need a navi on it really, basically the camera is my main goal. Thank you!
  2. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Look thru this list: Crutchfield.com for 2011 Prius two, but none of the installs are "easy", as you will have to install a camera and run the wiring yourself (or pay someone to do it.) You will need the head unit and an adapter (idatalnk or Axxess) that have pre-wired Toyota harnesses.
