Heart Transplant at 278,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by SnT08Prius, Jun 22, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,252
    Have you checked the cylinders for taper?
  2. Mendel Leisk
    41,413
    Oh hell, you can't just say things like that without explanation, lol.
  3. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    The bores look to be in good condition with plenty of hone marks still and almost zero ridge - and that cold be just carbon build up too.
  4. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Wouldn’t you want to put in The revised pistons and piston rings if you rebuilt the engine anyway?
  5. Mendel Leisk
    41,413
    The revised piston and ring set part numbers are in the attached TSB (they're stock parts for 2015 model year, and really should be used for any 3rd gen year, if you were replacing, or even if you have the engine out and disassembled). There's also a part number for a gasket kit, which I believe includes head gasket, and most everything else.
    Note also, there's parts in the TSB which seem to assume you're pulling the transmission too, so not all are relevant.
  6. Pat Campbell Cozzi
    Pat Campbell Cozzi New Member
    Oakland, CA
    Not I want to share. Yuck.
    Skibob likes this.
