Heat box
Discussion in 'Gen 3 Prius Main Forum' started by patrickjmoriarty, Jan 25, 2024.
Tags:
  1. patrickjmoriarty
    patrickjmoriarty Junior Member
    dublin Ireland
    Hi Guys and Girls,
    My 2010 Prius is not producing heat, toyota ssid the Heat Box is gone they want €1700 + vat for the part and €1400+ vat for labour. Is this correct. I'd appreciate any responses or information on this .
    52,841
    there's no way to diagnose it over the internet. could be right, or could be simple as the thermostat or coolant pump.
    if it is the heater box (radiator i assume they mean) itmight be buried deep in the dash requiring many hours of labor. the parts cost should be available at a dealer or internet parts source, as well as salvage parts for reduced cost.
  3. ChapmanF
    19,016
    There might be some chance of informed guesses over the internet, especially if you describe in more detail what it is and is not doing and when, and if you supply the trouble codes (if any). See the "Codes from the heat/air conditioning system" section at the bottom of this page:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Mr. F likes this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    Yeah you're talking about the heater core that's in the dash so you must have a leak or something that somebody can show you or point due or you have coolant on your floor of your car? Something or if it's not producing heat then coolant shouldn't be circulating around properly in the car could overheat and damage the engine or it may have already happened who knows generally leaks don't do too well especially when it's antifreeze or coolant for the ice engine. If there's no leak and the people who want to fix this for you tell you there's no leak and then you can start troubleshooting hoses and pumps and all of that but I have a funny feeling you must have some sort of leak no one's going to want to tear the dash out to replace the heat core in the dash unless it is leaking broken something's happening with it usually a leak usually you smell that fluid coming through your vent.
  5. patrickjmoriarty
    dublin Ireland
    Thanks everyone, I talked to various car mechanic's, it's the Heat core box . No leaks it has just packed in . Saving to change my car.
  6. Tombukt2
    13,855
    2,516
    Durham NC
    Maybe they could blow low pressure air through it and get what's packed in it out of it like stop leak or something I have no idea but air and or water should flow through the heater core without dumping on the ground or the floor of the car If it's not getting on the floor of the car and it's just stuffed up It may be able to be unstuffed or maybe not this is a job for somebody with a adjustable air hose compressed air a rubber fitting on the end of an air hose that can fill up the space of a heater hose so it can blow the air through it and see what comes out on the other fitting water stop leak coagulated nastiness whatever once the air blows through then water has a chance to go through and make you some heat. I can't imagine changing out a whole automobile because of no heat I can possibly because of a broken heater core that's going to require 20 hours of labor and tearing the dash out of the car then I would just regulate that car to summer use.
    patrickjmoriarty likes this.
  7. Tombukt2
    13,855
    2,516
    Durham NC
    Get a little propane heater one of those infrared types The screws right on top of a bottle put it in a cup holder right where you can see it You won't need it but for about the first 10 minutes of your ride.
  8. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    They make those for golf carts....for me, if it's that cold I'm not playing!
    Tombukt2 likes this.
  9. don K otay
    don K otay Junior Member
    35
    16
    Round Rock Texas
    Get a 300W inverter that plugs into the cigarette socket
    then get a Lasko MyHeat 200W ac heater.
    Both can be purchased at Amazon …. try it for 28 days then keep or return.
  10. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    That will likely blow the fuse for the outlet. Even if doesn't, 200 watts won't heat the whole interior enough to make much difference. Maybe if you're sitting on it ...
  11. ChapmanF
    19,016
    Yeah, the supplemental electric heat built into the car is 700 watts and I've never been able to tell when that's on or off (other than by watching the windshield clear a bit faster). It's a small fraction of the 5300 watts worth of heat you get from the warmed up engine coolant when the heater works.
    Still, you might consider posting the trouble codes here, or any other details those various car mechanics gave you, as "just packed in" isn't really something a person seriously diagnosing a heater problem is going to say.
  12. patrickjmoriarty
    dublin Ireland
    I talked to Toyota here in Tralee, Co. Kerry, Ireland and asked if there is any issue driving the car with no heat, he said as there is no leaks no error/warning messages. There should be no issue driving the car. I got a car heater that plugs into the cigarette lighter and I've been driving the car for a few month now. No issues . Still saving to upgrade the car .
