Heat/Defroster not Working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alex Prius, Dec 9, 2017.
  1. Alex Prius
    Alex Prius New Member
    Boston
    Hey Fellow Prius owners. I just purchased a 2004 Prius today and the heat and the defrost are both not working which is extremely un-safe as I live in New England. Inquiry regarding if anyone knows of this issue or any tips or ideas? Thank You
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Check the coolant level in the radiator by removing the radiator cap while cold, heat is often the first thing you loose with low coolant levels.
    JC91006 likes this.
    49,516
    welcome!
    is it not blowing, or only cold air?
    how many miles on her?
  4. ChapmanF
    15,696
    It's worth checking for any diagnostic codes from the heater. Hold down the steering wheel AUTO and RECIRC buttons together, while turning the car ON (two power button pushes, foot off brake). Wait for a beep and the MFD to switch to the climate screen. Post any two-digit codes you read from top corner of the display.
    -Chap
