Heat keeps getting redirected to floor vents with dash vents selected
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ualdriver, Dec 16, 2013.
  1. CharlesH
    2,796
    1,163
    Roseville, CA
    Can you imagine the fun the lawyers would have if you floored it to avoid an accident, and the system decided to NOT provide all the power it could? That information would in the "black box" data recorder.
  2. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    No grill blocking. 78 would be for the wife ;). I normally keep it around 74. If the trip is over 8 miles one way, I typically start in HV mode anyways and leave it in EV mode for the return trip. I've usually exhausted all EV by the time I pull into the garage even when below zero.
  3. markabele
    5,084
    1,782
    Nebraska
    Why not grill block? Super easy and it will pay for itself rather quickly.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    At about $2 dollars and 15 minutes to install. (y)
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yesterday went on a trip to northern Minnesota, two people 420 miles round trip. Early morning up, 10 degrees, late afternoon back 32 degrees. little wind, 10 mph or so.
    Set temp. in car at 68 degrees, fan speed 3 was quite comfy!, only could get 59 mpg on the read out. I'am happy! :D
    iplug likes this.
  6. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Does anybody know what the normal coolant temp is, driving on interstate at 65mph, for an extended time, I'm running about 197 deg.F with lower grill blocked! ( using Torque )
  7. markabele
    5,084
    1,782
    Nebraska
    That is pretty normal. As long as you aren't seeing it creep up into the low 200's you are fine. What was the temperature out. Personally I probably wouldn't do extended interstate drives with grill blocking in much above 30.
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Temps where in the low 20s until today when I had to drive south, it was 52 when I arrived at my shore house.
  9. markabele
    5,084
    1,782
    Nebraska
    Eek...and temps were still fine on the ICE at 52 degrees and 65 mph?
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    I had the windshield defroster on for about 15 minutes this morning. It didn't change until I hit the button again to turn the light off.
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Yes never went above 197f
    retired4999 and markabele like this.
  12. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    This happens to me too..This heater having a mind of its own.. It's a reL PAIN IN THE NECK I like my heat coming from the dash vents and a little from the defroster..
  13. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    Freeway speeds on level ground (or downhill) shouldn't be a problem at all, because the volume of air that makes it in past the blocked grille is much higher than at lower speeds. Long climbs might be an issue, but probably not at 50-60 degree temps. You can always blast the heater if you're worried about transient heat loads.
  14. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I never use auto. It annoys me that it starts with high (noisy) fan speed. Never had that problem with manual.
  15. bisco
    51,895
    same here. i hate when i bump it and the fan goes haywire.:eek:
    retired4999 likes this.
  16. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Me too!
  17. markabele
    5,084
    1,782
    Nebraska
    Yet more proof that everyone is different.
    I go on and on to family and friends about how the AUTO feature is one of my favorite of the whole vehicle.
    SAronian, Feri and giora like this.
  18. El Dobro
    El Dobro A Member
    7,088
    3,270
    I've owned a long line of cars that had auto HVAC systems. I guess that's why it does what I want. :D
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I find AUTO very effective both on A/C and heating. The start high does not bother me knowing it is for a good reason (complying to my demand of large temp difference). It automatically goes down to minimum required fan speed - another plus.
    My winter temps are not going very low though...
  20. bisco
    51,895
    i'm a control freak. i run my sprinklers manually and my thermostats. i need serious help...
