Heat wrap on cat convertor?
Discussion in 'Generation 1 Prius Discussion' started by Bruce Berquist, Dec 10, 2021.
  1. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    On my 2003 Prius Sedan I have a aftermarket cat system that does not have the HCVC contraption on it.
    Everything has been working fine and code free in relation to that so far.
    Until cold winter temps have hit.
    DTC p1436 popped up while driving after the car had warmed up.
    Since the gasses can no longer recirculate, and I believe that since the cat is cooling down when the gas engine doesn't run, that in this 18f temps on wet snowy road, I was wondering if exhaust heat wrap on the convertor might help prevent this?
    Any ideas?
  2. Tombukt2
    Tombukt2 Senior Member
    13,727
    2,484
    Durham NC
    Hot daum I missed something I didn't see anything connected to my cat except the silence are downstream in the same pipe I whack that off my muffler guy just connects to that and I didn't see any thing from the outlet of the manifold all the way back but I guess I must not have been paying attention I don't think I cut it out whatever it was but yes heat wrap will help hold heat in to whatever you're wrapping and even that heat across a pipe a tube a device
    SM-A715F ?
  3. Larry Grant
    Larry Grant New Member
    Reno, NV
    2003 Prius
    Bruce,
    My history with the 2003 Prius is very similar to yours. I bot one earlier this month that had the cat stolen. Bot a 2004-2009 ebay cat assembly and that has worked well, except for the missing HCAC. I too plugged the vacuum hose and now get P1437 and P1436 on a frequent basis. Here is what PATRICK WONG says about those codes:
    "The HCAC valve is stuck, causing P1436. You may be able to lubricate it with high temp lube to get more life out of it.
    DTC P1437 Vacuum Line Malfunction"
    Inverter Coolant pump issue figured out | PriusChat
    If he is correct, those codes directly relate to the missing HCAC valve and the plugged vacuum line. I've just bot a beefy looking choke pull off on ebay (just a little less than $8 delivered) and will install on the vacuum line when it arrives. I'll let you know whether or not that helps.
    Question: did you ever solve your emissions problems and, more specifically, what did you finally do about the plugged vacuum line?
    Cheers,
    Larry
    Bruce Berquist likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    In general, wrapping a CAT is NOT a good idea.
    It gets HOT by design and getting even hotter inside a blanket might burn off the pipes or start a fire.
    If this only happens during extreme winter conditions and does not make the car run really bad, I suggest that you just live with it.
  5. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    Sam. I hear and understand what you are saying and, to a point, you are correct.
    However, I have been using this trick for some time now and have no signs of any such problems. I do, and I recommend, header heat wrap of at least 1400F temperature range be purchased and used.
    I should also add that a 2" x 15' roll of 1400F heat wrap only covers about 2/3s of the first Cat, so the excessive heat still has some free opening to dissipate, but it allows that Cat to preheat just enough for the O2 sensor to sense that the catalyst is working properly.
    Now, I am only using this trick for very cold winter driving since it is only in that kind of climate that code p0421 pops up (never happens in spring/summer/fall), and it goes away with this trick. When hot summer driving conditions come I might remove the wrap if catalyst overheating seems to be arising.
    But up here in NH I really don't believe that such troubles will come up. So unless I go cross-country through the hot summertime south or southwest desert (or excessively hot rod or excessively cruise hard at upper illegal speeds) I don't believe that the heat wrap characteristics will be a problem.
    At the same time, your points are good, and it's good for people to give it some consideration and think about what kind of "hot" driving conditions or driving style is typical for them.
    Also, whenever any "non-typical" modification is ever made the driver should (as I do) monitor the modification for issues, especially safety issues.
    In the case of my experience with using the heat wrap, I have experience and observed nothing more than a slight hot fabric kind of smell when I made my first drive with it. Since then, there has been no sign of excessive heat issues.
    #5 Bruce Berquist, Jan 4, 2022
  6. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    Hi Larry. I did solve the emissions/inspection issue.
    It did involve installing a very inexpensive vacuum advance cannister on the vacuum line (bought an '84 ford escort advance vacuum cannister from ebay really cheap).
    It fixed all the Catalyst, O2, and Evap codes that I was getting. However now, with cold winter temps, code p0421 popped up during cold startup and in the first cold 5 miles driven.
    It is due to the missing HCVC valve also, due to a cold Cat warmup.
    I found that, for me, wrapping the cat in a layer of 1400F header heat wrap solved this issue.
    Now my 2003 Gen1 runs fantastically, like a new car, and with absolutely no codes.
  7. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    Over 2 years now with the heat wrap on the pipe front of the cat and partially on the cat, and with the vacuum pot installed in the HCAC vacuum line.
    It has made a huge difference in cold starts and warmup, and in cold weather driving, and gives no troubles over the summer months and on long interstate drives.
    There has also been a noticeable improvement in the average MPG during the cold weather months up here in northern NH.
    Not only did this help to trick the diagnostics system from giving me DTCs in regard to the missing HCAC on my aftermarket cats, but it has actually caused good efficient readings in the catalyst and O2 systems.
