Heated Steering Wheel
Discussion in 'Prime Main Forum (2017-2022)' started by Dennis_MA, Oct 27, 2017.
  1. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I noticed that mine work fine. However I don’t feel any heat at the very top or bottom of the steering wheel. I saw some comments previously about only parts of the wheel being heated. What are others experiencing?
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    pg 513:
    Heated steering wheel and seat heaters heat the side grips of the
    steering wheel and front seats, respectively.
  3. Dennis_MA
    185
    109
    Amherst, MA
  4. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    10 and 2...10 and 2.
    Tyfly and priuscatprimeguy like this.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    wait......12......no wait 8.........:confused:
  6. MNdriver
    MNdriver Senior Member
    549
    577
    10 and 2 plus 4 and 8
    priuscatprimeguy likes this.
  7. Mark57
    2,945
    2,740
    OK
    Does it change with daylight savings time?;)
    huskers and priuscatprimeguy like this.
  8. JMassey
    JMassey New Member
    Fredericksburg, VA
    Probably only if you have MoonStone interior though.
  9. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Not a prime number.
  10. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Optionally you can conserve power by heating only one side of the steering wheel
    Mark57 likes this.
  11. But 2017 is.
  12. Since2002
    936
    1,098
    Duluth, GA
    Yeah that's the reason for the hold up on the new model, they have to wait for 2027
  13. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    Just got my new Prime. I had the same question about the top of the steering wheel (part between the laces)not heating. Good to know. Thanks!
  14. memasterac
    memasterac Junior Member
    SF Bay Area
    The "Partially (half-A-S-S)" heated steering wheel only heats up roughly between 2~5 and 7~10 clock position. Large portion of top and small portion of bottom are not heated :(:(
    jaqueh likes this.
  15. huskers
    2,548
    2,488
    Nebraska
    That is to make you a safe driver.
  16. Mark57
    2,945
    2,740
    OK
    So you bought a vehicle to be very energy efficient and your upset it's not wasting energy by heating the majority of the steering wheel that's not being used. Right . . . :rolleyes:
  17. memasterac
    SF Bay Area
    Different perspective my friend, I bought this car for the CA green Decal.
    Respectively disagree. Your interpretation of safety applies to a steering controller, not a round wheel.
    Ron L Thompson likes this.
  18. Tideland Prius
    16,650
    Unfortunately that is/was the standard for heated steering wheels (just the sides).
    However, I have noticed that manufacturers are starting to heat the whole wheel. (Recall that heated wheels were on luxury cars that typically had a wood/leather steering wheel. From my understanding, they only heated the leather covered part and not the wood covered part so it became the standard to heat just the sides even on fully leather-covered wheels)
  19. Oniki
    Oniki Active Member
    652
    499
    Colorado
    You will not say that after the airbags inflate
    Lee Jay likes this.
