Heater/AC won't turn on
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by mcd51, Jun 19, 2017.
Tags:
  1. mcd51
    mcd51 New Member
    2014 Prius c
    New member, ... 2014 Prius C (approx 31K mi). After parked in 95 deg heat, AC/heater would not turn on. Hitting AC button only caused info to appear briefly on screen, but no AC/heater operation. Let car sit overnight, repeated, same results. AC/heater had been functioning fine up to this point. All comments welcome.
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Is the fan blowing?
    What info was displayed on the screen?
    #2 DonDNH, Jun 19, 2017
    52,849
  4. mcd51
    mcd51 New Member
    2014 Prius c
    OK, just took a fifth look at the control buttons & noticed that the OFF button had become jammed. Augh. Thx DonDNH for reply, ...
  5. mcd51
    mcd51 New Member
    2014 Prius c
    bisco, .... see above. :^P Thx for reply.
  6. bisco
    52,849
    i have a sticky fan speed switch. this didn't used to happen to toyota's. glad you found it!
  7. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I was going to suggest you check this as soon as I saw the thread title. It seems to be an issue that catches a fair number of people, myself included.
  8. zeuloa
    zeuloa Member
    30
    26
    Managua, Nicaragua
    2014 Prius c
    Happens to me all the time!
    iPhone ?
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Yes it's a common problem.......with ALL of the climate control buttons.
    You'd think that they would have fixed that by now.
    My new '17 hasn't done it.....yet.
    If it does, I think a tiny drop of silicone lube will be applied.
