Heater and climate control
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rockerdan, Sep 14, 2012.
  1. El Dobro
    El Dobro A Member
    7,102
    3,282
    Whatever setting I left it at when I shut the car off, that's the setting when I start it up again. I don't see why, but maybe the PIP is different.
    52,742
    so if the outside temp dropped, and it got cooler than 75 in the car, would the heat come on?
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Yep, the system would do what's necessary to maintain the setting.
  4. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Ill be testing this more as weather cools.....If it "remembers" the last setting, that will be great ! I can see in winter having it set to say 72-74f AUTO and AC OFF. So when you get in car it would aim for this temp, and assume it would start ICE to get the heat.
    Dan
  5. El Dobro
    El Dobro A Member
    7,102
    3,282
    My Cadillacs had automatic HVAC systems and they woudn't blast heat until the system hit a preset level. I wonder if this system does that.
  6. bisco
    52,742
    makes sense, but if the ice doesn't fire, 'she ain't never gonna get there'.
  7. El Dobro
    El Dobro A Member
    7,102
    3,282
    That's probably why the heating grids were stuck in there. My TDIs had them too because diesels take some time to start throwing off heat.
  8. bisco
    52,742
    well, i just thru the manual. nothing at all about heat. there are more pages dedicated to 'remote a/c' than anything else. i suppose they figure we should know how to use heat after all these years?:cool: RD, are you sure the ice didn't fire and you thought it didn't because no heat was coming out? it does say 'immediately after AUTO is pressed, fan may stop until warm air is ready to flow'.
  9. rockerdan
    427
    83
    Wheatfield NY
    Yep i went thru manual too...odd isnt it? So much aimed at AC but little to nothing about heat and ICE.
    My ICE DEFINITELY did not fire up, I specifically was watching the large EV logo on HSI, radio off so I could hear, waiting for ICE to fire when i cranked to 85. Nada.
    Now, is it true there are ELEC heater lines in the system? I did notice the air that blew was NOT COLD, but it was not hot or even warm. I would say it was same temp air as inside air was. I wonder if this was ELEC warmed air? Since the 59 outside temp would have felt cooler i assume.
    So noone had their PiP early last spring or winter? I thought many PiPs were purchased around January. I honestly thought when i started this thread many would chime in and tell me exactly how it works since I assumed many had their cars last winter.
    Seems there are more questions then answers on the heater! LOL
    Dan
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    That's exactly what the Caddys do on AUTO.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    That's the only way you're going to get any heat without the ICE warming up. In the standard GenIII, they come on when the temp control is all the way up.
  12. rockerdan
    427
    83
    Wheatfield NY
    Does anyone know for sure if the PiP has elec heat within the system? I think tonight is gonna be another chilly night around 45f. I will try to take a ride late tonight and see if the ICE kicks on when i drive in EV mode.
    Dan
  13. Chris11
    Chris11 Member
    220
    Washington
    I was curious so went out to my PiP in the garage. Inside the garage (according to the car) was 68. Inside the car (according to scan gauge) it was 64.8. I hit auto, increased the temp to 85, and the fan speed to Hi. The ICE didn't come on just as Rockerdan reported.
    The only change I noticed was after my overnight charge the EV miles said 14.2 and whenever I hit auto to turn on the fan, the reading went down to 12.5. Turn off by auto and immediately back up to 14.2. On 12.5, off 14.2.
    I also played with the fan speed while on the upper dash vents ... and there was zero heat. So I'm thinking there aren't any electric grids either in the PiP.
  14. El Dobro
    El Dobro A Member
    7,102
    3,282
    Check the readouts with and without the temp all the way up. The grids should have a pretty big draw.
  15. rockerdan
    427
    83
    Wheatfield NY
    Ok, that seems like a larger draw then just FAN ONLY. I think fan on/off only is about 1EV range mile. You are reporting more. I wonder if this could be elec coils?
    I agree mine was not hot, but it was similar temp to inside even in FRESH AIR mode(non recirc) Could elec coils just heat the air up enough so its not COLD air blasting? Seems ELEC coils would need alot of power to run if they were actually HOT.
    More questions then answers! LOL
    Dan
  16. Chris11
    Chris11 Member
    220
    Washington
    Ok...you convinced me to go out again....lol. From 14.2 to 12.5 does seem excessive.
    I put a digital thermometer into the dash vent. Hit auto. Fan came on and I didn't notice the AC lit up. I heard the compressor cycle on and off a few times but didn't realized at the time it was the compressor. I was watching the EV miles and it never changed from 12.5, with the compressor off or on. I then noticed the AC was lit. And the vent temp was 50.x. I turned off the AC and set the temp at 65, around interior temp but 4 degrees higher than ambient in the garage.
    The dash vent temp went up to 63. I increased the temp to Hi. And the dash vent temp DID go up 68 and stopped there. I turned the heater temp back down to 65 and the vent temp dropped to 63 again. And I could hear a difference in the fan speed. The 12.5 EV miles did drop to 12.3 by the time I'd finished. And once I turned off the fan it only went back up to 13.8.
    So you've convinced me there is some kinda electric grid that's coming on. It doesn't provide much heat ... just enough to take the chill off.
    This wasn't very scientific ... partly because I was freezing and my hand was cold from holding the thermometer in the vent so I rushed it. Perhaps the thermometer would have been lower or higher with patience.
  17. rockerdan
    427
    83
    Wheatfield NY
    great experiment thanks!
    this makes sense, as when i was driving the air coming out seemed similar to inside air, when outside was only 59. It was not cold but was not hot. Im guessing this was possibly an elec coil that just barely uses much power, but will warm air enough to blow air that is not cold from outside. But since i was in fresh air mode it must have been heating it somewhat.
    This will be interesting in the coming days/weeks/months to see how the heater in AUTO plays out...I am going to leave mine in AUTO when i come home this afternoon, with heat set to 80f and AC OFF. Then when I go out tonight Im hoping it "remembers" that setting leaving AC OFF especially. Then ill take a drive in EV to see what happens.
    My guess is there must be a certain TEMP that is low enough(or temp difference) that will fire the ICE. And this temp of 59f was just not cold enough to call for ICE, even though i was calling for 85f. The car is smart enough to realize I did not need HOT air, just the luke warm air of a possible ELEC element, we will see.
    Great work Chris!
    Dan
  18. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Im sure we will start seeing more of these threads as the cooler winter weather approaches....
    I have had this idea since I purchased my pip. I wonder if there is an AC or DC powered heater that can be sat on a seat or in the rear hatch that will heat the car. If its AC then we would need to install a power inverter. If it had a remote that would be pretty nice feature too. Remote climate control without starting the car. Me likes :)
    Obviously there would be concerns about running the 12v battery down. The user would have to look at how many watts the heater consumes.
  19. bisco
    52,742
    i have to disagree that outside temp has to be below 59 for the ice to come on. that's just too cold for us seniors!:p
  20. Chris11
    Chris11 Member
    220
    Washington
    Thanks Dan ... do not know how accurate it was though.
    And bisco ... you're right. Aging takes lots of heat....lol. Not only are we in the SS crowd, both my wife and I are on diets trying to lose weight for our upcoming cruises. Less carbs = less body heat.
    The lil ole PiP will be complaining about the extra weight it's hauling back from Miami. :)
