Heater and climate control
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rockerdan, Sep 14, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Oh cruises... Im taking my girlfriend on a cruise out of Baltimore this January that I need to start thinking about getting in shape for.
    The last time I took a cruise I worked out every single day on the ship. Weights, ran about 4 miles etc and I STILL gained 14lbs! Its crazy how much you eat on a cruise!
  2. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
  3. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Interesting....Id love to know why there is not one mention of this supplemental heater in the thick manual.
    I forgot to mention I did try pushing the ECO button last night(putting it into normal mode) , and it did allow the fan to run faster, but did NOT start the ICE still. I only tried NORMAL mode for a few seconds though.
    Dan
  4. rockerdan
    427
    83
    Wheatfield NY
    I just got back from a EV drive down to the riverwalk where i Bike. Its a perfect 15.1 miles(round trip) and I do this drive quite abit. I take a slow route so most times I make it round trip all EV.
    anyway, before i took off i did a couple quick tests....
    I started car at 14.1 EV range, and hit AUTO, which turned on AC and range dropped to 12.4
    Then i turned off.....
    Next I tried same thing but AUTO with AC OFF, same exact thing, dropped from 14.1 to 12.4
    Next I hit AUTO with AC OFF, and turned TEMP UP to 80f. Same exact thing, dropped to 12.4
    So the way it looks to me, the FAN itself is what drops the EV range, I know we have talked about this before and It does not look to be a bigger drop with HEAT TEMP HI. So its really only about the FAN.
    Next I did a quick test on Memory. Yes the Climate control remembers its last position, which is nice....So in winter if we leave TEMP set to say 72f and AC OFF, it will save that for the next morning. Nice.
    One thing i also noticed, If you turn AUTO on, AC OFF and call for HEAT(warmer then outside temp) it seems to default the VENTS to the FLOOR ONLY. So if you want face/floor, or defrost floor ect....it wont stay there, it goes to floor only in AUTO/HEAT mode.
    Id love to find some more documentation from toyota about the so called HEATER.
    I left my car just now with temp set to 80f and AUTO ON with AC OFF. I will go out there later tonight when its cooler and will see exactly what happens.
    Dan
  5. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Is it possible that turning the AC to off turns heat off also?
  6. bisco
    52,875
    i hope not.:)
  7. bisco
    52,875
    there is an old thread from last winter discussing how toyota dropped the expensive heat pump that was in the test vehicles and only left the electric heater.
  8. bisco
    52,875
    so RD, still no ice? i'm dieing to try it, but we haven't had any cool weather yet. not that i'm in a hurry.:)
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    The car also has a water jacket going around the exhaust pipe to heat the coolant faster when the engine is running.
  10. rockerdan
    427
    83
    Wheatfield NY
    Im waiting another hour or two, its supposed to drop to low 50s......Ill let you know.
    Interesting about the coolant wrapped around exhaust....ill have to take alook and see if i can see this.
    Dan
  11. El Dobro
    El Dobro A Member
    7,106
    3,282
    You can see it around 1:50.
  12. Jimbo69ny
    712
    107
    Ithaca, NY
    Guys, "Auto" functions the same in all vehicles that offer that feature. Its not black magic. It keeps the car at the temp you desire. If it needs to cool, that's what it does. If it needs to heat, that's what it does.
    Just like all cars that have "Auto", they also have independent AC and heat controls.
    Don't worry about the heat. It will work when the time comes.
    As for heating in the prototype version, that car had a remote heating system just like our remote AC system they decided it wasn't a cost effective option to offer so the removed it. We still have a traditional, Ice driven, heating system in our production pips.
    Andyprius # 1 likes this.
  13. rockerdan
    427
    83
    Wheatfield NY
    Ok Just got back from a test....slightly cooler tonight then last night.
    tonight it seems to work as I assumed it would. It does not come on right off the bat though, it took about 2 miles of driving with AUTO on 85f until finally it kicked on the ICE. Until then it just did not blow at all, or very very low.
    Now, i tried a few more things.....
    I shut off, then started back on EV again.....and put back down to 70f. I then slowly increased, and it seems that 76f was when it would kick on the ICE.
    I also did same thing with manual mode(not AUTO) I started at 70f and when i got to 76 it kicked on, same thing.
    Im not sure why last night none of this happend on a 14 mile drive, while tonight it happened within a few miles. I wonder if me trying it last night for its first time, somehow made it work tonight as it should. odd.
    I did not get any sort of feel of an elec heat coming out, but who knows.
    I guess winter drives are gonna be HV to get any sort of warmth, the heated seats should help some but for those cold days will surely use ICE more.
    Im guessing once its much colder inside car the 76f threshold to kick on ICE tonight would be much lower.
    Dan
  14. rockerdan
    427
    83
    Wheatfield NY
    Forgot to say I opened the windows this time...I think that helped get inside temps down lower. last night maybe the inside temps were just not cool enough??
    Dan
  15. bisco
    52,875
    thanks RD, good to know it works as specified.
  16. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Dan, I received my PIP in early March, and had the heat and ICE come on a few times with cooler mornings. I had to lower my temp control to LOW to keep it from starting the engine. I'd get your car checked by the dealership, something doesn't sound quiet right. When you moved your temp to 85 deg it should have fired up.
  17. rockerdan
    427
    83
    Wheatfield NY
    yeah it was odd that first time i tried it on a fairly long drive, nada. But then last night all seemed to work normally as it should. I wonder if once i powered off, and then used it again the next night it may have reset something? I know I had never tried heat ever, so maybe that first time it takes a power down or somthing. who knows.
    I sure hope we can just leave it OFF and use heated seats if we dont want ICE to run ever, I would like that option of dressing warm and using seats only.
    on Another note, the seats dont seem to rob any EV range like the fan does. Might run off the 12v.
    Dan
  18. rockerdan
    427
    83
    Wheatfield NY
    Hey guys....something I completely forgot to post from my test last night.....I thought I did but i forgot something very important.
    the reason the first night my ICE did not kick on, was Im always in ECO. Last night it did not kick on until i pushed ECO again, then it was in "NORMAL mode" this is when i got the ICE to kick on.
    I think in ECO the ICE will not kick on when calling for heat, except for when its MUCH COLDER outside then 59f.
    Dan
  19. bisco
    52,875
    so, in normal mode, does the ice fire when you adjust the temp to one degree higher than the temp inside the car?
  20. rockerdan
    427
    83
    Wheatfield NY
    It seemed to kick ICE on when i hit 76f only.....Now there might be a specific "difference" between actual temp and what temp is called for. But last night 76 was the magic point where ICE kicked on. Temp outside was 57f.
    So if you go out to test....just be sure to turn ECO off, this seemed to be the reason i could not get ICE to fire the first night.
    More testing as weather cools for sure...But it seems ECO tries to save ICE from firing for sure, which is good for not wanting ICE.
    Dan
