Heater blow hot air only when engine kiks on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Arsl, Dec 22, 2021.
  1. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    2007 prius heater give hot Air Only when engine kiks on?can anyone help plz?
    #1 Arsl, Dec 22, 2021
  2. JC91006
    16,936
    8,647
    Normally you would need the engine to kick on to circulate the coolant, that's how hot air is able to get into the car. There will be occasional times where the heat will come through without the engine if your temperature is set a little lower.
    Arsl likes this.
  3. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    Thanks jc91006 i have set my temperature at full but still the heater give me hot air only when engine is on otherwise when my car runs on battery/hybrid he start give me cold Air never seen problem like this before if engine keep going on the hot air keem coming on
  4. ChapmanF
    19,011
    When the engine is off, the coolant is circulated by a separate electric pump, #8 in this illustration, to make sure you still get heat. If that pump isn't working, the coolant will circulate only when the engine is running, which would have symptoms like what you describe.
    This heater pump (#8) is separate from the engine water pump (not shown here), and the coolant storage water pump (#20), and the inverter cooling pump (#1).
    Yes, a Gen 2 Prius has four water pumps under the hood, three of them electric.
    #4 ChapmanF, Dec 22, 2021
    Mendel Leisk and Arsl like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Great post.
    Also could be an indication that the thermostat is stuck open.......or missing......so that the coolant never gets up to the proper temperature.
    audiodave and Arsl like this.
  6. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    4 water pumps
  7. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    Thanks Thread i have recently changed thurmalstat still same much Appreciate for for comment
  8. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    Thanks brother i will try to fine #8
  9. ChapmanF
    19,011
    That one pump is expensive beyond my wildest dreams for some reason.
    Ok, I mean I guess I've had more expensive, wilder dreams, but they sure weren't about water pumps.
    But I would probably still begin by maybe touching that pump with a mechanics' stethoscope and see if it is or isn't running when the engine has stopped and the heat is on. If it isn't, maybe look for a cause in the wiring or a fuse or relay first, and save shelling out for the pump unless you become convinced it's at fault.
    #9 ChapmanF, Dec 22, 2021
    Arsl likes this.
  10. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    As this is a UK Prius, it only has 3 pumps. There is no CHRS or its related plumbing.
    Nevertheless, one of those 3 remaining pumps still is the #8 in the preceding diagram.
    Arsl likes this.
  11. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    Thanks every one today engine light has appear as well the code is PO420
    I search this code on Google it says its 02 sencer
    Now i am wondering is this sencer is making problems with hiters?
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Here is a pic of the heater pump- from the front of the car facing the firewall and brake actuator with the inverter removed. DSC_8363.jpeg
    Before considering replacement I would be testing the wiring to make sure that it can provide power and ground to the pump. Then I would carefully supply both to the pump to make sure it was in fact dead. Then I would check ebay for a used one.
    #12 mr_guy_mann, Dec 23, 2021
    Arsl likes this.
  13. mr_guy_mann
    4,113
    2,011
    NJ-USA
    P0420 is a code indicating that the ecu thinks that the catalytic converter efficiency is too low. That code could be caused by a faulty (upstream) Air-Fuel sensor, OR by a faulty (downstream) oxygen (O2) sensor, OR by an exhaust leak somewhere near either sensor, OR by the engine running very poorly, OR by a dead converter.
    Search the Gen2 forums here for more info. That code by itself shouldn't affect the heater operation.
    Arsl likes this.
  14. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    I have also noticed coolant is freezing cold inside radiator even if i drive my car long time is that fine?
  15. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    What do you call that pump
  16. ChapmanF
    19,011
    I gave a direct link to it in post #9.
    Arsl likes this.
  17. Arsl
    Arsl Junior Member
    Sheffield/england
    Active
    O sorry i did not notice thank you v much
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    NO.
    Not fine at all.
  19. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Your vehicle must have a cooling system. If you said after driving the car the coolant is still cold you have a problem. What is your mileage? If it were me I would start with a water pump and thermostat.
  20. 2010moneypit?
    314
    122
    Beaumont ca
    Oh yeah I forgot to mention PO420. Relates to a converter efficiency. I believe these cars have coolant lines going to the converter. Not sure if the coolant lines are to keep the converter warm or to keep the coolant warm. Either way all these problems could be related to your cooling system.
