1. ToddFromNC
    ToddFromNC Junior Member
    North Carolina
    My heater quit blowing hot or warm air all of the sudden. I took my mechanic and they said it showed no codes and were afraid to mess with it so I took it to a dealership. They worked on it most of a day. Said nothing showed a code as bad, they got into it and found the air going into the heater core was hot, but it was cool coming out? They spent some time flushing the coolant and said they found some sediment in the coolant fluid. They were hoping to flush out anything clogging the heater core?
    I am $200 down from the work they did and really have made no progress. Still cold air. The estimate to replace the heater core (all Toyota knew to do next) was around $1200.
    I guess I wanted to get some other opinions? I could probably take it back to my local mechanic and he could do the heater core for less. I am not sure if there is a prius specialist mechanic in the Raleigh/Durham area. And I am just wondering if there are other options?
    Thanks for any input.
    52,863
    the air going thru the heater core should be cold going in and hot coming out. the coolant going thru it should be hot going in and warm coming out. it could be a bad core, but you should get a second opinion and price. try a local triple a mechanic? you shouldn't need a hybrid specialist for this sort of thing, although, there maybe some special requirements when replacing the coolant, i'm not sure, i might be thinking brake fluid. certainly get your local mechanics opinion.
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    Thatss what happens, if you don't change the collant every two to three years. Something in the system evidently corroded, and the residue most likely clogged the heater core.
    Depending on where it is under thae dash, it might tahe 5-10 hours of labor. So, $1200 might be what it will cost to replace it.
  4. Patrick Wong
    18,210
    6,526
    My opinion is that the heater core coolant pump should be checked to verify it is operational, prior to going to the trouble of replacing the heater core. If your local dealer's service dept is unaware of the existence of this pump, find another dealer.
    How many miles on the odometer?
    Note that the original pink Toyota Super Long Life coolant is good for 100K miles.
  5. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The following is unlikely to be the OP's issue, but it could be.
    The Gen II Prius does not have an engine temperature gauge (although it easily could and should have one).
    so we really don't know what the temp is without additional equipment (OBDII scanner/readers).
    I had a Camry once with a stuck open thermostat. The temp gauge reading remained just
    above the cold mark no matter how far I drove and I had no heat until I replaced the thermostat.
  6. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    There are several used car dealers in the Raleigh/Durham general area that sell quite a few Prius' a year. They get them worked on somewhere. I would look on Craigslist to find them and call to ask where they would recommend taking it.
  7. epoch_time
    epoch_time Active Member
    240
    113
    las vegas
    Sounds like the coolant transfeer valve is stuck/bad
    This is a 3 port valve on the drivers side next to the radiator (on the drivers left of radiator).
    It directs engine head coolant to either thermos storage container or heator core...
    There was a report about a year ago of no heat... he replaced valve and reported sugsess..
    He purchased some sort extended hose clamp removing tool.. but had to drain coolant...and as you might have read
    getting air bubbles out of coolant system is no joy..
    The documented functions of the valve are PREHEAT where heater core is blocked off allowing thermos coolant to only enter
    the ice.
    The next valve function is ENGINE WARM-UP where the valve blocks flow to the thermos bottle and opens flow to the heater core..................................
    The next valve function is DRIVING where flow is both to heater core and thermos bottle.....................
    The next function is POWER-OFF where the thermos bottle route is closed the same as warm-up position.................
    If you drained coolant prior to no heater condition then you should suspect air bubbles .... however if you havent drained coolant
    check into coolant transfeer valve... When bad the dealer can read codes but only dealers code seem to read codes for bad transfeer
    valve..
    There is also an electric heater coolant pump that operates when gas engine stops and heater system is on...
    Hope this helps..
    I'mk trying to attach pdf file shows prius cooling system hope this works
  8. ToddFromNC
    North Carolina
    Thanks. On the question on miles, 144k. On the coolant flush every two years... I had it done at 100k which is what the manual said, but I don't think the Toyota coolant was used... but would that cause this problem after 40k miles?
    Looks like I should find an option that is less expensive for a prius specific mechanic? Or just take the hit and use the dealer? Don't know where to start except calling around to used car places as suggested. Bummer.
  9. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There does not seem to be any problem with coolant in the Prius, as far as PC'ers are reporting, that indicates frequent changes are needed. But that assumes Toyota SLLC is used. It would be good to change to that. It may be that, as posted above, the valve is stuck. I'm guessing that the SLLC may have better lubrication properties, to help keep such valves working.
