Heater help
Discussion in 'Gen 2 Prius Technical Discussion' started by Jimlarge, Mar 6, 2023.
  1. Jimlarge
    Jimlarge Junior Member
    28
    MN
    2007 Prius 220k
    -Months ago replaced coolant control valve with new one off ebay due to code which I don't remember. At this time the car had no symptoms, just the code.
    -Heater worked fine always, then one day it didn't blow hot air. Blower works fine just always cold regardless of all settings on the Climate control.
    -Added coolant, bled coolant, added, bled, as per prius coolant guidelines. It did take about 1/2 gallon. This all started about 3 weeks ago. I have regularly checked the coolant since.
    - 3 weeks ago Had code B1442
    -Swapped "air inlet servo motor" It seemed this part was working correctly before and after swap as we could see it move.
    -Swapped "air conditioner amplifier" No change.
    -Those 2 parts were from a salvage car.
    Cleared codes, moved climate system through all variants.
    Still no heat.
    today - 15 miles later 2 codes popped up P1116 & P1121
    How should I proceed?
    #1 Jimlarge, Mar 6, 2023
  2. BiomedO1
    BiomedO1 Senior Member
    4,480
    2,355
    Left Coast
    If this model has an electric coolant pump, they do get sticky and doesn't move coolant as efficiency as it should. Coolant control valve is also a high failure item at that mileage.They are mostly plastic and disfigure/wear-out over time. Have you been doing your recommended coolant changes? Check your HVAC coolant valve is opening up; allowing hot coolant into your heater coil.
    You've got a sticky throttle body, needs cleaning out.
    Hope this helps.
  3. ChapmanF
    18,936
    The P1121 indicates problems with the coolant flow control valve, which was replaced with a "new one off eBay" "months ago", so that seems to be about how long a "new off eBay" coolant valve lasts. The P1116 indicates incorrect behavior of the coolant temperature at the thermos outlet, which could quite easily be because of the faulty valve.
    I suspect you meant to type B1442, right? That's a legit Gen 2 Prius heater code related to the air inlet servo. Heater codes are body (B) codes, not powertrain (P) codes.
    There is some other model of car somewhere that has a "P1442" powertrain code about an engine air injection system. A Prius doesn't even have that system (or, naturally, that code), so googling for what it means in some other car is just a distraction when working on a Prius.
    If you were able to see the old heater air inlet servo moving before you replaced it, probably that means the B1442 code was set by an electrical issue that was intermittent, and wasn't a problem right when you happened to look.
  4. Jimlarge
    28
    MN
    Correct B1442.
    So you think I should change the coolant control valve again?
    Does the coolant temperature at thermos outlet indicate thermostat?
    I'm trying to compile a list of what to attempt to have my bases covered and get this heater going. It's cold here in MN.
    Thanks!
  5. ChapmanF
    18,936
    No, the 'thermos' is a large hot-coolant storage tank under the left fender. A problem with its outlet temperature much more likely indicates a problem with the coolant control valve. It is generally not coincidence when P1121 and P1116 both come up.
    A Toyota coolant control valve from a dealer will probably last longer than months.
  6. Jimlarge
    28
    MN
    So it looks like we're pointing to the coolant control valve.
    Is there a way to test the one I have to verify if it's faulty?
    Is there anything else I should try or check?
    Thanks again for all your help!
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    With some fancy equipment that very few people have, you can verify that the coolant valve is bad. Experience has shown that a P1121 is 95+% likely that it's the valve.
    Toyota released a Technical Service Bulletin that states, you get that code, you should replace the valve.
    You should first inspect the wiring for problems (like rodent damage). Then put a Toyota part in.
    While you're in there, you might want to look around for any leaks or seeps. Usually if the coolant level goes down at all, then it's gotta be going somewhere.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Though likely mistaken, you should be able to actuate the coolant control valve from within techstream.
  9. mr_guy_mann
    4,109
    2,011
    NJ-USA
    Techstream or any capable scantool that has bidirectional controls should let you command the valve.
    I have seen a few where the valve moved just fine, but the position sensor was glitchy enough to set a code anyway. Only "saw" the problem by putting a scope on the signal circuit.
  10. Jimlarge
    28
    MN
    I plan on replacing it I do have techstream. Where do I go in techstream to test the valve? I do not know how to test any actuators or valves in the techstream program. I do a health check to check the codes.
    If you can point me in the right direction I think I can figure it out.
    Thanks!
  11. mr_guy_mann
    4,109
    2,011
    NJ-USA
    In Techstream, select Engine and ECT / Active Test - activate the water flow valve. The number 3, 4, or 5 denotes which of the three possible positions the valve can go to- 2.5V, 3.5V, or 4.5V (2.5V seems to be the default).
    So select "activate the water flow valve 4" or 5, scroll the data list all the way to the right - water flow valve is 4th from the last data, hit the "right arrow" - it will go from off to on and the data should shift to the commanded position.
    As mentioned, I often see the valve "work fine" on this test, but using a scope will show the bad position sensor that's triggering the code
