Heater in Extreme Cold
Discussion in 'Prius c Main Forum' started by brown67, Feb 8, 2014.
  1. brown67
    brown67 Junior Member
    Colorado
    So I got a Prius c back in September and love it. Question about the heater. Heat has worked great until this last week when we had an arctic cold front come down. I work nights so when I got off work this week it has been -10F to -15F. I have been staring the car and letting it warm up and start defrosting the windows as I'm finishing up work (I'm a UPS Feeder driver). The problem I'm having is the car never gets really hot. Usually the heater blows me out of the car. This last week I have had to keep the fan and temp on high all the way home(30 min. drive). I'm not cold, but wondering if this happens to other people who live in cold areas of the country.
    Also, if I switch to just just having the heat on the floor it does get a little chilly in the car, so I have been selecting floor and defrost and that keeps it comfortable. This morning it was 12 above and the heat was back to normal and had to turn down the temp and fan after a few minutes. I think the car is just struggling with the extreme cold.
    One really nice thing about a Prius c in cold weather. It starts right up since there is no starter motor. Turn the key and the electric motor kicks on and then the ICE motor comes on.
  2. KYBlue
    KYBlue Active Member
    227
    112
    I've found in extreme cold turning ECO mode off really helps get heat quicker/hotter. We've had a rough cold snap here the last month also and It's been wicked!
    Fahfoofnik likes this.
  3. brown67
    Colorado
    Yes, I did that on the second day of the cold snap it does help.
  4. Fore
    Fore Don't look back!
    494
    107
    "I have been selecting floor and defrost and that keeps it comfortable"
    Somtimes using floor and defrost turns on your AC compressor at the same time. To heat up your car quicker use selection foor/front dash and make sure your outside fresh air is off. Also, make sure the auto temp. control button is off.
  5. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    I have a C4 and in the past couple of weeks it has been below -10°F on the 18 mile drive to work. The car warms up quickly and I did not notice any loss in cabin heating performance. I assume that all Prius C's have auto climate control so I don't understand the need to manually control the fan or temp settings. Perhaps the high altitude in Colorado makes a difference in heater performance (it's only 900 ft. elevation in Indiana).
  6. El Dobro
    El Dobro A Member
    6,979
    3,214
  7. c4
    c4 Active Member
    607
    51
    Block the grill so the engine can stay warmer, and inside the cabin, use the defrost button vs. the floor vent- for whatever reason, it warms up the cabin faster and more effectively. Also keep the fan speed in the low speed range for the first little while.. You might be tempted to go with a higher fan speed, but that just cools the engine down faster while it is trying to warm up. Use the temperature dial- I set it for 22C- don't crank it because the system actually adjusts how much engine coolant goes into the cabin heat loop based on this setting, and opening it all the way just slows down engine warm up and cabin warm up.. In addition to keeping the temperature setting at an appropriate level, I generally never go above 2-3 bars on the fan unless the windows are really fogged up and I need them cleared fast and I have no problems with heat up here in Canada where it's -20C in the mornings.. If you want to take the edge off the first couple of minutes before the engine has warmed up enough to start providing cabin heat, I'd suggest spending $20 at the auto parts store to buy one of those heated seat cushions that plug into the lighter socket.. They are amazingly effective..
  8. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Get a Prius engine block heater. Inexpensive and it works well to have a fairly warm engine coolant as you get in the car on these cold mornings.
  9. Fahfoofnik
    Fahfoofnik Member
    98
    32
    Plainfield, IL
    I have done this a few mornings recently, and when the wind chill is -21F or worse in the morning, my Prius C II *does* warm up a LOT faster with ECO turned off. I just don't worry about MPG in the winter now, it sucks in the cold pretty much no matter what I do. I'd rather be warm faster & spend a few extra bucks than wait forever for the windscreen to be defrosted & my extremities to have feeling in them.
