Heater issue! No hot air. Read many forums. Heater core hose not hot!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fliebly, Feb 18, 2020.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,697
    806
    Southern California
    There isn't normally anything that fits that description in a coolant loop. The closest would be the rubber in the hoses. If one were failing badly enough to slough off that many pieces it should feel soft at that place (less rubber) and you might be able to see the damage inside from one of the ends with a flashlight. That said, I have never heard of one doing this. Blowing up or splitting, sure, but coming apart inside? Also, if chunks of rubber were coming off of the inside of a hose why would it develop voids which were not in the original rubber? Maybe if a section or all of it had overheated really badly? It's either that or somebody stuffed black foam rubber into your cooling system, which doesn't seem very likely either.
  2. Fliebly
    Fliebly New Member
    22
    Tx
    It is the same color as the hose. Maybe just being cycled around and around in the various pumps the pieces of foam takes on the dexterity and form of foam.
  3. ChapmanF
    18,309
    My brain still isn't able to go anywhere with this other than some odd undesirable chemical reaction, maybe between constituents of mixed coolants, or maybe between constituents of coolant and of the hose material.
    I may have nightmares for a while about the dexterity of this foam.
  4. pasadena_commut
    2,697
    806
    Southern California
    If the crud came from a hose the first order of business would be to be sure said hose is no longer in the cooling loop. The link in #23 is interesting since it suggests some combinations of coolant and hose chemistries can produce problems like this. I don't know about you folks, but one black rubber hose looks very much like another to me, and surely many hoses have been replaced on Priuses with whatever the local auto shop had on hand without this sort of disintegration taking place. So at the very least give the current hoses a very thorough inspection, and if in doubt, replace them.
  5. Fliebly
    Fliebly New Member
    22
    Tx
    Just wanted to thank y’all for the dialog. I got all the air out of the system today and the heater returned to functioning. Conclusion, there was blockage in the heater coolant loop of an unknown foamy substance in the auxiliary water pump behind the inverter for future reference. After I found the blockage, I did a complete coolant flush. Used a water flush on the loops to check for blockage. Changed the part, filled the system, and purged all air out of the system.
    #24 Fliebly, Mar 6, 2020
    valde3 and Raytheeagle like this.
  6. Mendel Leisk
    41,637
    It was from the engine coolant circuit? I'd assume so, if it's affecting cabin heat.
    If you've got any of that stuff, see if it'll dissolve in a 50/50 mix of white vinegar and distilled water. That formula is recommended for dissolving/flushing one stop-leak product, FWIW.
    Maybe you're out of the woods now, but if you have issues down the road, something to try.
  7. LDT08
    LDT08 Junior Member
    16
