Heater not blowing hot enough
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jama707, Jan 19, 2024.
  1. Jama707
    Jama707 Junior Member
    SACRAMENTO, CA
    even though I replaced the three-way valve recently I think it could be the problem - i've this kind of whirrring noise from the pump area
    07 Prius noise - YouTube
  2. Jama707
    SACRAMENTO, CA
    I'll get a new one and see if changes, usually it usually throws P1121 but i don't have it
    Tombukt2 likes this.
  3. dolj
    dolj Senior Member
    8,620
    4,375
    Wellington, New Zealand
    Maybe if you got a cheap knock-off or caounterfeit unit from Amazon or eBay but it might not necessarily be the valve itself. It could be a wiring issue or a connector issue. Proper diagnosis will sort out where the problem is.
