Heater Settings
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Nov 10, 2016.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    This last week the morning temps were in the mid 30 degrees. The heat came on with the fan at full speed. Strangle I couldn't feel a lot of temperature change. And a high pitch whistle. It took a while to figure out the heat was coming out of floor vents only. So I manually changed it to be floor and dash vents. That's the way I like it. Unfortunately it is now not the setup for automatic button. Any one know it you can setup a default heat configuration that it would go to when you hit Auto?
  2. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    Even though the auto button is not lit up it is still in auto. The fan speed will still self adjust and the temp will still be automatically controlled. I threw me off the first time too. Just another Prius quirk.
    RCO likes this.
    52,776
    i use manual for those very reasons. ask the dealer if they can change the setting, if it's not in the manual.
    RCO and Sooner Al like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    That's odd. I checked mine - was on AUTO, RECIRC & A/C. It let me turn the A/C OFF and still kept AUTO.
    RCO likes this.
  5. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    Try changing where the air comes out, that's when the auto light goes out. Weirdly enough it still operates in auto.
  6. alanclarkeau
    7,045
    7,593
    You mean the Climate's ECO settings? I'll check.
  7. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    No change from say the vents to the floor or vice versa.
  8. Mendel Leisk
    42,264
    This predicates on it being similar to 3rd gen:
    Hit Auto, then the override you want, say High/Low mode. Then if you for example turn the system right off, you have a couple of ways to turn it back on:
    1. Hit Auto (ok, but will dismiss your high/low setting)
    2. Hit Up on fan speed (this will turn the system on, with all your previous override still)
    JDenyer232 likes this.
  9. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Yes I knew it was still on automatic temp control. I was looking to use the auto button to set everything back to my configuration. In my Honda you touch anything and everything is manual. I don't like it. The Prius is not bad.
    JDenyer232 and RCO like this.
  10. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I'm not aware of any vehicle that allows you to permanently set the defaults for the Auto setting. On hot days the fan speed comes on at the max in all of the cars that I have owned. I wish that I could set an upper limit.
    RCO likes this.
  11. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    More unnecessary Prius complications!! :confused:
    I should have bought a used Toyota Echo.
    Or that $11,000 Nissan Versa.
  12. Coast Cruiser
    2,267
    2,571
    I had a weird thing happen. Three mornings in a row, when I got in the car there was a big wet spot on the inside of the windshield, right at eye-level on the driver's side. That never happened before. And I haven't been doing anything different with the HVAC or vents, etc.
    And no amount of defrosting or heat would remove it. I finally had to stop, and get a towel and wipe the inside.
    It hasn't happened again since.
    Just another Prius Oddity...
  13. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    That sounds like a lot of moisture in the car.
  14. Coast Cruiser
    2,267
    2,571
    Beats me. It hasn't occurred again. I will add that to my growing list of weird Prius things.
    Leading the list, are grabby brakes that throw me into the dashboard. If I had to explain this car to somebody, tell them all about the ins & outs… I wouldn't even know where to start! :ROFLMAO: It is the strangest car I have ever driven.
    Gotta keep telling myself… Don't analyze it, just drive it. (But the strange and weird things keep piling up.)
    RCO likes this.
  15. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    There's a lot of stuff going on to make a Prius do what it does. Braking switching from regeneration to friction braking being just one of them.
    #15 Gen 2 Tom, Nov 12, 2016
    RCO likes this.
  16. Coast Cruiser
    2,267
    2,571
    HAL 9000
    I've been driving in the "Normal" drive mode for 3 weeks now, and I noticed the AC is not getting as cold as it once was. I have it set at 65 degrees, and it sure is not 65 degrees! I can barely feel any cool air. Even when fan is cranked up.
    HAVC Eco button is not on.
    Vents are at high/low.
    All systems are normal.
    Just ANOTHER Prius Oddity.... :cautious:
    Every day is a NEW adventure. :ROFLMAO:
    The HAL 9000 computer must be mad at me, or something.
  17. JDenyer232
    JDenyer232 Member
    44
    48
    Maine
    I'm sorry I can't do that Dave:ROFLMAO: As far as the brakes grabbing go, that's an easy fix. Because the Prius relies on regenerative braking, the friction brakes often don't get whole lot of use. As a result they get a light coating of rust on them from humidity, rain, etc. When the friction brakes do kick in and there is a film of rust on the rotors it grabs and tries to throw you thru the windshield. The fix is to get the car up to 50-60mph, put it in neutral and apply the brakes firmly, repeat this a couple of times and that grabbyness will go away. The Gen 4 can safely go into neutral at these speeds and not over speed MG1, previous Gens have lower speeds. Hope this helps.
    RCO and Coast Cruiser like this.
  18. Mendel Leisk
    42,264
    I do not know. On our third gen, I'll get occasional VERY grabby brakes, just at start up, typically in reverse. Touch the brakes and it feels like you just HIT something. This is not surface rust on rotors, likely software bug. They have zero modulation: it's off or locked.
    Only lasts a few seconds, shift to D and ok.
    Coast Cruiser likes this.
  19. Coast Cruiser
    2,267
    2,571
    Several people with a Gen4 have reported the grabby brakes. Mine occurs mostly at slow speed's when going down the driveway, or slowing down to stop at a red light. Just something I have to be aware of.
    But when I was shopping for cars, I did also see many Prii's that had rust on the rotors.
  20. Mendel Leisk
    42,264
    Rotors invariably rust, with any car. They're non-stainless (odd expression) steel. Wash the car and let it sit a day or two, the rotors WILL get a rust bloom, and be a bit noisy for a block or two.
    RCO likes this.
