Heater Slow to Warm
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by thameslives, Dec 1, 2016.
  1. thameslives
    thameslives New Member
    Baltimore, MD
    Four Touring
    Hey y'all,
    I've got a 2008 Prius Touring, and as winter is approaching here in MD, I've noticed that the heater is taking MUCH longer to start blowing warm air - at least 30 minutes of the engine running. The fan seems to be working just fine, but blowing cold air.
    That said, at Jiffy Lube today they tried to sell me the coolant/radiator flush, which apparently I am WELL past due. I guess what I'm looking for here is the most common causes of that issue, and how likely it is that a $90 flush at JF will correct the problem.
    Thanks in advance!
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Two things I'd check: thermostat (stuck) and coolant control valve (that can throw a trouble code).
  3. Jeff64
    Jeff64 New Member
    US
    My 2008 stars out good then loses heat the longer it is on. Any ideas?
  4. JC91006
    16,477
    8,394
    Your coolant level might be the problem. I would change the coolant.
    You should probably not do it at jiffy lube, they probably don't have the correct coolant and they probably have no idea how to bleed the air out
    #4 JC91006, Dec 1, 2016
    Lui Baiguer and Mendel Leisk like this.
  5. ChapmanF
    15,464
    Before grabbing the wrenches, I'd plug in an OBD-II reader (any ought to do, coolant temperature is a standard parameter), and watch the coolant temp during that initial half hour when you're feeling cold air.
    If the coolant temperature is really taking that long to warm up (to 80 C or so), get out the wrenches and look at the thermostat.
    If the coolant is getting warm reasonably fast, but you still get little heat in the cabin, think about occluded passages (which that coolant flush might unblock somewhat).
    Having the data first will help guide your direction.
    -Chap
