Heater temp.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by magnumrtawd, Nov 9, 2013.
  1. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Queston?
    If I have the heater temp at 70 and the auto temp and A/C off with the blower on. Will the engine still run to maintain heat or, just run to maintain performance??
    I do have the grill blocked.
    Has any body installed a aftermarket temp. gauge on a 08 pri.?
    Where would you install the sensor?
    I do have a Torque app. and adapter but I would prefer a permanent installation.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Which temperature do you mean? There are (at least) 7 different temperatures that are worth monitoring. Engine, MG1, MG2, Inverter, Converter, Battery upper and lower. Inquiring minds will want to watch these change over time, so Prii-dash is a permanent installation in my car.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Your question is tough to answer partly because I almost NEVER use auto on the HVAC of my Prius.
    See details about engine coolant temp towards the end of my post at Why mileage gets worse in winter | PriusChat.
    I can tell you that when auto is off, the trigger points at which the ICE will turn on varies depending on the temperature setting (heat demanded). If you want to learn where those are, you'll need to use something to monitor engine coolant temp (e.g. ScanGauge II).
  4. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Do you know what the thermostat temp should be?(open-close)
    I have the torque monitor sys and at highway speeds it stays at 186.6.
    Around town it never exceeds 168.
  5. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I would like to install a conventional coolant temp. gauge.
  6. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Just get a scan-gauge and you can select any temperature you like. Google it. H
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    For the Gen-II model of Prius, the threshold for the heater is 145°F.
    That means if you have the heater on, the engine will stay off (if you don't need power for thrust beyond the electric motor) until coolant temperature drops below that.
    For the Gen-III model, that threshold can be dropped to 114°F using the ECO mode.
    For the PHV model (plug-in), the minimum I've observed it drop to the upper 80's with the right conditions in the dead of winter. And unlike the other models, it varies based on the heater temperature you set.
    Long story short, block the grille and just drive it. If you want to squeeze out more, buy an aftermarket gauge to monitor coolant temperature.
  8. John C.
    John C. New Member
    Monroe. GA
    When you say "block the grille", I am assuming that you mean shove a piece of cardboard in between the radiator and condesor. Is this correct?
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    You can stuff some water pipe insulation foam into the grill.
  10. john1701a
    12,840
    5,312
    58
