Heating solutions
Discussion in 'Environmental Discussion' started by maggieddd, Feb 4, 2007.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    <div class='quotetop'>QUOTE(etyler88 @ Feb 5 2007, 11:54 AM) [snapback]385566[/snapback]</div>
    I am not renting other units
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(hyo silver @ Feb 5 2007, 11:48 AM) [snapback]385561[/snapback]</div>
    Very true. But I did say be careful around curtains, just being the cheap, I mean frugal person I am, not seeing the point of going out to buy some special dust when there are basically free alternatives around.
  3. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(Mystery Squid @ Feb 5 2007, 11:52 AM) [snapback]385564[/snapback]</div>
    if you were paying around $500/month, then I guess I am doing really good and shouldn't be complaining.
    No kerosene for me, thanks
    We tried to stuff an expandable foam in the cracks but I am pretty sure there are many more holes. I am going to check that out tonight.
    I am thinking of the film for the windows. The problem I've heard with those was that it alwasylooks cloudy outside through the windows which have the film applied.
  4. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(maggieddd @ Feb 5 2007, 12:01 PM) [snapback]385571[/snapback]</div>
    The 3M stuff I used was almost invisible. Follow instructions carefully, I had to mess one or two up before I got it right, though.
  5. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(etyler88 @ Feb 5 2007, 11:44 AM) [snapback]385558[/snapback]</div>
    Definitely something to think about. Thanks
  6. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    <div class='quotetop'>QUOTE(maggieddd @ Feb 5 2007, 01:56 PM) [snapback]385569[/snapback]</div>
    OK, I'll admit to being confused. If you are living on the 3rd floor, and you are not renting the other 2, is anyone living in them? Are you heating "empty space"
    Overall, the ideas have been stated, verify proper insulation in walls and ceiling (you do not go on the roof to check roof insulation, it is in the attic), caulk around windows, and, if they are not insulated windows (meaning single pane or removable storm window type) consider replacing them. Biggest heat loss is by poor insulation or poor sealing of outside air. Lastly, if you furnace is old and inefficient, replace it.
    Oh, if you do have empty space you are heating, I have read that under some circumstances it is actually unwise to cut off heat to interior unused rooms because interior doors are poorly insulated as are interior walls and you simply bring in cold air to cool the rest of the house. There are many variables here so I would recommend just experimenting here.
    Auxillary heat sources are not solving the problem, only masking it. I also use a progammable thermostat that regulates my home temp based on my daily use patterns.
    Just my thoughts, good luck to you.
  7. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    If you turn your heat all the way off during the day, I think it'll use excessive amounts of energy to heat your house at night. Plus, kitty won't like it. Also, I think your pipes can freeze if you do this.
    Look for cracks. I found half inch gaping cracks around the gas pipes that enter our house. I sealed them with that expanding foam. Look at the interior where your furnace is to see if there are any gaps between the pipes and the walls or floors. If your windows are double paned, I don't see how they can be a problem except that you may have leaks around the frames that should be caulked. Also, look at any doors that you have with light shining through from the other side to see if you have any visible gaps. Lastly, someone else mentioned ceiling fans. With ceilings as high as yours, you'd very much benefit from their use. Make sure that you have the blades revolving the right way for winter conditions.
  8. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(SSimon @ Feb 5 2007, 02:50 PM) [snapback]385652[/snapback]</div>
    ceiling fans are out of question. I have beams so there is no space for ceiling fans.
    maybe I won't completly shut the heat but what if I lowered it to like 50 degrees during the day? I don't think it will take excessive energy in the evening to heat up the house. Force heating works quite fast and I think it takes the same amount of energy to get to 67 degrees all at once as having the furnace turn itself on every 30min or so to keep it at 67 degrees (I haven't actually calculated this, so I might be wrong).
  9. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    <div class='quotetop'>QUOTE(maggieddd @ Feb 5 2007, 11:56 AM) [snapback]385569[/snapback]</div>
    So why are you living on the top floor? I think you'll find this is the coldest floor in the house and therefore the one that needs most heating. This is because it loses heat through the roof whereas the middle floor gets the extra insulation of the floor above and the one below. But the ground floor is probably the warmest. At least I find this in my own house which is also old and on three floors. In very cold weather there is a conspicuous difference in the temperatures, going down as you go upstairs. In summer it's the opposite, with the top floor often being too hot on a summer day because of the sun on the roof.
  10. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(Oxo @ Feb 5 2007, 03:17 PM) [snapback]385667[/snapback]</div>
    because the third floor is new and second hasn't been remodeled for many many years, there is another reason why but I won't get into explaining this here. Anyway, second floor is where kitty goes pooping (his sand box is located there)
  11. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I don't want to pry into your living arrangements, Maggie, but if kitty has the second floor to himself, he's likely keeping the temperature where he wants it, and he's got a fur coat on. No wonder you're cold. :)
  12. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    You might check to see if your local power company will do a free energy audit. Many will. They will come in with fancy gadgets that can detect the biggest heat loss locations.
  13. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(maggieddd @ Feb 4 2007, 11:17 PM) [snapback]385585[/snapback]</div>
    The "crappiness" depends on how "handy" you are, the stuff is not that hard to put up. I'd certainly try it myself before paying someone, but my frugalness has been noted in this thread already. Seriously, it's not that hard to put up, and very inexpensive.
  14. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Maggie
    I'm unsure of the age of your home, but let's guess around +50 years old? Unless the renovation was a complete gut of the interior, I'd be very surprised if you even had any insulation in the walls. Or if you did have insulation, there probably isn't a vapor barrier to speak of.
    Air infiltration can be a significant factor for high heating bills, especially in a climate like mine where this morning it was -39 F. Even if vapor barrier is installed, it tends to be just overlapped on seams with no real thought given to making the product work.
    As an example, it's code here to use Tuck tape on all the seams to completely seal the vapor barrier. Electrical boxes must be special airtight design, the the vapor barrier is also Tuck taped to the box sealing flange. Acoustic sealant is applied to the bottom sill to seal the vapor barrier to the sill.
    On the exterior, Tyveck housewrap is used, all seams Tuck taped. The windows are also Tuck taped to the Tyveck house wrap to ensure a building envelope as tight as possilbe.
    You mentioned the roof being recently redone. If it's a cathedral ceiling using regular batt insulation you're lucky to have an R-30 value. But you mentioned exposed beams, if that's the case then the ceiling R value may be under R-20. If a closed cell polyurethane foam, like BASF's Walltite brand, was used, then a 6 inch layer should be close to R-40.
    Since heat rises, your third floor (Top floor) "apartment" should be the warmest in winter. Unless the heat loss through the ceiling is very high. You could easily verify this with infrared thermography, which is best done in early morning before the sun rises. I use infrared thermography to inspect motor control centers and three phase transformers at industrial sites.
    Skylights overall are a horrible idea in a climate that can get colder than +20 F in winter. Even a triple glazed window only has an effective R value of around R-6, maybe R-8 with dual argon gas fill and dual low-e coatings. By contrast a 2x6 wall filled with batt insulation is around R-20.
    The age of the furnace can't help your *system* efficiency if the ductwork is uninsulated and not sealed. DOE reports and studies on residential energy efficiency determined on *average* a minimum 20% of the total system air input was lost due to ductwork that was uninsulated and unsealed.
    http://www.energystar.gov/index.cfm?c=home...provement_ducts
    To try any changes to your house, just how easy is it to get to the walls and the ductwork? If it's an older house with plaster walls, you're talking a very major gutting to even see what if any insulation is in there, let alone vapor barrier. If the ductwork is buried behind plaster and gyproc, again a major gutting to get to it.
    I'm good at framing, plumbing, and excellent at electrical, but even I know when to draw the line. Almost always I prefer to build new, as I have total control over the process, since I do it myself. Though I'd sooner give myself a castration than hire it out to a "contractor."
    You'd be surprised how many "contractors" asked me what I was doing when I was going through the pile of lumber, carefully eyeballing each stud, and placing an "X" on one side. They were clueless about the concept of "crown" in lumber. My Dad taught me that as a kid. Scary. Trust the "professionals" at your own peril.
    About all I can suggest that won't break your budget is to consider an infrared or radiant gas heater. They're very energy efficient and make you feel warm
    The house I used to have in the burbs had 2x6 walls with BASF Walltite closed cell urethane insulation, triple glazed Polar thermal windows, a R-70 roof, and a Bryant Evolution Plus 90i two stage gas furnace with heat recovery ventilator. I did most of the construction myself, and I also sealed the ductwork and insulated it with R-20.
    For a cold winter month with average lows of -20 F, my natural gas for heating and hot water worked out to around $230. In summer to heat the hot water cost $30.
    My house at the hobby farm has exterior walls of insulated concrete form. In my opinion ICF is the only way to build a house, I'd never do it with stick framing again. For January with our bitter -30 to -40 lows, the gas bill was $128.
    A lot of people claim energy efficient construction just doesn't "pay" off. Bull. Even if you break even, the home is way more comfy, no drafts, and quieter too.
    Good luck with your heating problem. If you have any more questions, please feel free to PM me with details.
  15. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(maggieddd @ Feb 5 2007, 01:58 PM) [snapback]385657[/snapback]</div>
    This will definitely save you some money. How much depends on all your other variables. If you don't have a programmable thermostat get one so you can have the heat start about 30 minutes before you get home and then your pad will be nice and toasty when you walk in the door.
    It's a common misconception that it takes more energy to heat up the cold house than to just leave it warm all day long. If you didn't have a cat taking the temp even lower during the day would save a few more ducats.
  16. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(hyo silver @ Feb 5 2007, 04:03 PM) [snapback]385689[/snapback]</div>
    but the kitty has a running nose today.
  17. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(jayman @ Feb 5 2007, 08:04 PM) [snapback]385794[/snapback]</div>
    Jayman, thanks for such an extensive post. Yes the renovation was a complete gut of the interior. I didn't have a complete oversight of the insulation process but as I recall R-20 was used in between rafters and R-16 in the walls. I have a closet with a gas furnce on the 3rd floor in the apartment. My main duct for the heating is in the pitch of the roof and I am wondering even though it was insulated with maybe an inch thick padding since it rests in actual pitch of the roof, that there might be a substantial loss of heat just there. The beams are not exposed, they are actual collars that were just boxed for decoration.
    I will consider getting the infrared thermography. Where can I get that?
    Tomorrow I am going to check for infiltration.
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ Feb 5 2007, 08:40 PM) [snapback]385817[/snapback]</div>
    thanks, I do have a programmable thermostat. I've had it set up to keep temp at 63 at night and during the day and 67 in the evening. I am think I was have to test the cat and see ow low of a temp he can take.
  18. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    <div class='quotetop'>QUOTE(Display Name @ Feb 5 2007, 06:49 AM) [snapback]385506[/snapback]</div>
    Yikes!
    I would seriously recommend NOT doing this. You might get away with not venting your cooking, depending on how much you do, but the dryer vent should always, always, always be vented outside if you have a gas dryer. Besides being absolutely laden with moisture that might cause condensation in your home and make you feel cooler, it is also full of the products of combustion. Like carbon monoxide. Which you can't smell, and can't see, but kills over 200 people a year in this country as they sleep in their beds.
    I talk to the survivors of such accidents every winter, and they would gladly have spent a ton of money on energy rather than lose their loved ones.
    Gas appliances should be vented, especially in a house that you are "sealing up" to save money on energy. If you have random headaches, a slight quesy feeling in your stomach, or a feeling of lethargy when inside, you could be experiencing carbon monoxide poisoning. It will kill you eventually.
    By the way, 50°F is fine for a cat during the day. He'll curl up somewhere and conserve heat; a box or one of those kitty houses will work great. In an enclosed space, he'll quickly heat up the space and be very comfortable.
  19. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    <div class='quotetop'>QUOTE(maggieddd @ Feb 5 2007, 06:48 AM) [snapback]385502[/snapback]</div>
    From personal experience:
    I use to live on the second floor of a very drafty 1920's fourplex, but was quite comfortable, even on cold [California standards] nights. This apartment building had free radiant floor heat. Not that the building was built that way, but because the elderly gentleman below me kept his apartment blazing at 85 degrees day and night. My floor was warm to the touch! I actually had to open windows if I did not wish to sweat to death.
    My suggestion: Try heating the apartment below you instead of your unit. A warm floor and cold ceiling is much more comfortable than a hot ceiling and cold floor.
    Solar Panels:
    This is one of those cases where not having your location in your profile puts everyone at a disadvantage. <_<
    Do you live in a California-ish climate or a Minnesota-ish climate?
    Geographic location makes a big difference. Site location and orientation makes a big difference. Solar heat may be a good option for you in an old drafty house. Have some solar experts come advise you on options.
    Some day I hope to build a house with a six inch concrete slab floor with hydronic radiant floor heat hooked up to lots of cheap solar panels. I will pump lots of heat into the slab and regulate the house temperature by opening windows if needed. [yep, I miss that drafty old apartment with warm floors :wub: ]
    http://www.the-mrea.org/download/HydronicFloorsFactSheet.pdf
    http://en.wikipedia.org/wiki/Underfloor_heating
    http://www.eere.energy.gov/consumer/your_h...m/mytopic=12590
  20. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Feb 6 2007, 01:28 AM) [snapback]385938[/snapback]</div>
    thanks. I don't know what happened but I had location listed in my profile. I am in MA. I'll try heating the 2nd floor and see what happens.
    <div class='quotetop'>QUOTE(fshagan @ Feb 5 2007, 11:34 PM) [snapback]385896[/snapback]</div>
    Funny thing is that when we were temporarly on the second floor the cat used to sit right on the heating registers when the hot air was blowing (the heating registers were on the floor on the second floor, they are in the ceiling on the third floor, so he can't do that any more) I will test him in 50 degrees.
