Heavy load = higher MPG!?!?!?
Discussion in 'Prius c Main Forum' started by Mikey The Mailman, Mar 23, 2013.
  1. Mikey The Mailman
    Mikey The Mailman Delivering snail mail for you ;-)
    96
    Sacramento area, CA
    I'm confused!
    My car now has 9,300 miles since July. I normally drive 25 miles each way to/from work with 95% highways.
    After work 2 days ago, I stopped by Home Depot & loaded 16, 12'X12" concrete step stones in my trunk (protected by thick old blanket) and drove 10 miles home, sure it feels heavier but I noticed 99mpg for couple miles even with gas running. by the time I got home it was 74 mpg!!!!
    Yesterday after work, I did the same picking up the last 16 of same, drove home the same way giving me 76 mpg.
    Today, it was back to normal 46mpg trip (cold morning) and 55mpg (cooler afternoon)
    What gives????? Makes me think I should leave that in my C all the time LOL (No way!!!)
    And yeah, I shouldn't load that much in the first place :whistle:
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Mikey The Mailman likes this.
  3. Mikey The Mailman
    96
    Sacramento area, CA
    Elevation from home depot (20 feet) and my home is 43 feet
    I've frequently stopped at stores to pick up food, and while engine was warm, I never saw what I saw in the last 2 days with very heavy load!!!
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Was the weather warmer than usual?
  5. fuzzy1
    10,174
    To really test it, stop by Home Depot on your next commute home in similarly warm dry weather, resetting the MPG gauge but going home without picking up any load.
    What MPG do you get? By excluding the engine warmup portion of the commute, it will beat the usual 55 mpg from work. I'm guessing it will match or beat your loaded HD trips.
  6. Mikey The Mailman
    96
    Sacramento area, CA
    It was cooler weather while the first time I picked up a load was a windy day then the next day with cooler and calm winds
  7. bisco
    49,509
    sounds like you need to stop at the donut shop every morning!:p
  8. Mikey The Mailman
    96
    Sacramento area, CA
  9. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    More weight = Car sits lower = Better aerodynamics = +20 mpg increase! Simple! :rolleyes:
  10. DKTVAV
    DKTVAV Active Member
    510
    101
    To OP, did you test this way yet?
    If you want to be fair wait the same amount of buying stuffs in the car and then drive home.
  11. Mikey The Mailman
    96
    Sacramento area, CA
    Yes, I did today on my way home...I stopped by chipotle which is in the same shopping center as Home Depot...it's normal and the temperature was around the same! (n)
  12. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    and... ?
  13. DKTVAV
    510
    101
    I believe he's saying "it's normal": not higher MPG with heavy load.
  14. Mikey The Mailman
    96
    Sacramento area, CA
    What I'm saying is on every day daily driving my mpg reminds the same UNTIL these 2 days I loaded up 16 square foot concrete step stones which heavy thus boosted my MPG to the mid-70's! THAT'S what got me confused as WHY would heavy load cause higher MPG than empty (except me, of course) load!?!? Ever since these 2 days of heavy load, it's back to normal to mid-45 to low 50's (due to cooler weather here)
  15. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Haven't you ever heard of the "heavy load MPG fairy?"
    SuperABM and Mikey The Mailman like this.
  16. Mikey The Mailman
    96
    Sacramento area, CA
    :ROFLMAO:
  17. mahout
    mahout Active Member
    655
    116
    NC
    I have a sneaking suspecion that youchanged the angle of the car with the extra weight thus thinking it had more gas than it did.The weight also drops the car which has less aero drag and thus you let it think you were getting more mpg. And of course there's not more downhill is there? More weeight means more work to speed up and slow down so should mean less mpg, too.
    MissP likes this.
  18. vindicator
    vindicator Junior Member
    Rochester, NY
    I've read that two reasons the C does not get not substantially better mileage than the hatchback is that 1) it's shorter, so the Cd (coeff. of drag) is higher and 2) it lacks adequate mass to capitalize on regen during coast down. The concrete blocks may have temporarily alleviated that issue.
  19. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Except that he says he lives 20ft uphill elevation wise, from the Home Depot.
  20. vindicator
    Rochester, NY
    If it's a couple of miles between Home Depot and his house, elevation difference is negligible and can be ignored.
