Heavy Springs And Lift Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by strawbrad, Nov 24, 2019.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    why would you suspect this? why not that it would make the ride better?
    it happens on all lifts, particularly on the Gen 3. What promotes one over the other is that the smaller lift visibly looks not lifted and you have less ground clearance.
    re: the herd... It's not my concern if someone doesn't like it when I speak about those who are truly in the herd as those who aren't blinded by the words of those online and can see why I call the herd.. the herd... those are the people I make parts for. What happens is, once an owner installs the 1.5" lift and realizes I was right and my words were the truth they end up buying a 2" lift kit and offering their apologies for believing the words they initially read online. You see... there are many non-customers who are very vocal out there and most I don't even think they lifted their Prius.
    have a look here and there are other videos I've been posting to showcase the fact the vocal voices are not truthful in their words!
    - YouTube
  2. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    I have the 1.6” lift, without any spring upgrades etc. No rubbing at all. Not even close!
    mattbuilt1 likes this.
  3. mattbuilt1
    mattbuilt1 New Member
    NH
    This is really helpful! No rubbing even when up on jacks? Did you do PU or metal spacers? Any issues with the included hardware?
  4. Has Raf
    Has Raf Member
    180
    43
    PU, which were cheaper than a set from places such as Prius Off-Road. The garage did have an issue with the bolts originally, I can’t remember what the issue was, but they got em fitted in the end. There’s not rubbing when lifted on jacks neither. Depends on tyre size too. I have 195/65R15s fitted at the moment.
  5. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    personally.. i never understood the allure of going cheaper even as it relates to Tylenol, I guess I work too hard to not spend my money well on quality parts. that said..
    the issue.. .PU lifts aren't designed to keep the suspension proper when lifting. plus, vehicles that are made for off- pavement usage that are lifted don't use PU lifts... but to each their own. heh, you wont find a tacoma or jeep with no PU lift kit, so why trust it on your Prius? Truthfully, if they had an issue, I'd be concerned as, there shouldn't be an issue... particularly with bolts. but.. you know.. this is why the lift kits I manufacture have the studs welded into the lift kit...
    Do Not Buy Plastic Prius Lift Kit
  6. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    There's alot being deleted when people post about different things out there... you see, they try to sweep a lot under the rug. Like the whole axle rubbing jazz hands... or bolts breaking and bending on their kits... so think... if you have a PU kit that's not as strong as the metal how much fun you'll have fixing should damage occur... no one wants to post about issues that happen particularly with the PU kits as everyone would say we told you so.
    https://black.jmyntrn.com/?s=offroad
  7. Has Raf
    Has Raf Member
    180
    43
    I’m not doing any offroading in my Prius. The lift is just for kerbs, drives, potholes etc. Big problem here in the UK.
  8. James Analytic
    330
    52
    Michigan
    Yeah, I've had the 40mm PU spacers and RubberShocks on my 2006 (keep in mind we're on a Gen 2 post and not Gen 3 to clarify) in the front and rear and the front with no CV shaft axle rubbing issues other than when using oversized tires and then the wheel well rubbing fender liner issue. That's with 215-75R15's. Almost 40K miles now, though I don't run the larger tires much anymore since I like better fuel performance since driving farther more this last year.
    No K-frame spacers, whether being washers, nuts or custom machined scrap. I like the K-frame spacers, great idea and work regarding, though not a requirement from my observations at the lift height I've been doing. Though I'm doing nothing heavy duty hardcore off road as of late, still. Sway bar linkages are the only rubbing I've observed and that's on the lower control arm. Thinking that might be due to having longer Corolla sway bar linkages and not adjusting the sway bar maybe? Both my control arms on each side have had bushing go bad, rear bushing tore rubber on the drivers side (jafinch78 YT video detailing) and either the bushing or bolt is going on the passenger side front one.
    On another similar note...
    I know I'm planning to cut some yard KYB-Toyota front strut knuckle mounts off in the morning to get for a custom spacer for when I do do a K-frame spacer lift. That video I linked looks super inspirational. I'm thinking I can fabricate so can be cut in the back like inside opposite the knuckle, pressed while bolted to go around the strut sides, weld a spacer strip to fill in the backside of the cut part and therefore make an adapter that can be re-used on a different pair of struts so not having to weld to the strut.
    I'm almost debating cutting the k-frame sections off and using those stacked as a spacers since I don't recall ever seeing a yard gen 2 k-frame removed and taken. Would be neat to use Toyota materials from like two or three gen 2 k-frames as the spacer. Tie rod nuts come to mind with the castle-crown part removed. I can't think of where else larger washers are used on any Priuses or other Toyotas. Any thoughts? Seems somewhere there are and I'm not recalling, maybe I found when cutting something up.
  9. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    you know... you dont have to do all that work if someone like me has 3D scans of what you are trying to cut...
  10. mattbuilt1
    NH
    Many of your answers seem to be conspiracy-obsessed which, given that we are talking about Prius mods, comes across a little unhinged. Definitely not like I reliable source of information. You might want to keep that in mind. I tried to read your plastic lift article; it needed proofreading to the point of being incomprehensible.
  11. mattbuilt1
    NH
    Do you think the control arm bushings might be wearing out because the Rubbershocks reduce your travel, transferring more stress to other components?
    I haven’t done the sway bar upgrade yet (looking forward to it!). I thought the Corolla/Matrix/Vibe links were not compatible, just the sway bar. The control arm rubbing could also be an upside-down link.
    I am interested to see that video - what is the link?
  12. James Analytic
    330
    52
    Michigan
    Might be, I removed and quieted up. Definitely not as clunky.
    Read into the sway bars on Priuschat, as I understand they are for certain year ranges. Where the Corolla are next stiff, Vibe next and AWD Matrix most where those are solid if I remember correctly at least in regards to the rear. I thought the 2009 Corolla one I got is supposed to be, though I need to purchase new bushings and mounts. I also grabbed at a half off sale another rear Prius sway bar with plans to fabricate front strut mount tower braces using the Toyota material.
    FYI.. the gen 2 Prius rear strut axle mount side washers are the washers I was thinking about that can be used stacked as K-frame lifts. I checked on a 2WD Matrix and those washers are smaller in diameter and thickness on the rear struts. I'll try to cut out the rear K-frame mount pieces as well to see how might perform as a K-frame spacer.
    Two videos I took as a sanity check and to share my experience. jafinch78 - YouTube
  13. Paul Gregory
    Paul Gregory Senior Member
    2,153
    563
    Alberta
    2024 Prius Prime
    XSE
    My 3rd Gen Prius was too low to the ground. It was getting stuck in snow far too often.
    My 5th Gen Prius Prime is slightly higher off the ground, and I haven't had it stuck yet.
    If the low clearance was intended to save fuel, my Gen 5 has slightly better fuel economy with the higher clearance.
  14. James Analytic
    330
    52
    Michigan
    How about your gen 2 compared? Lifted or not, this is a gen 2 forum post.
  15. Paul Gregory
    2,153
    563
    Alberta
    2024 Prius Prime
    XSE
    Framed for contrast.
    James Analytic likes this.
  16. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    there's a saying about kicking a horse when it's down but ill paint you a better picture. some folks struggle with getting all their thoughts out on the keyboard and written, but you know what... that's okay., I find that once constructive criticism is laid out it can be like a set of requirements to improve the code.
    around late 2021 is when I mentioned the whole axle rubbing situation.
    shortly after on various prius online social watering holes I was looked at like I'm making it up or its okay, if it happens is what they wanted folks to think... heck they even went as far as to say its a gimmick I'm trying to sell.
    https://black.jmyntrn.com/2024/01/06/how-can-i-eliminate-this-axle-rub-it-started-occurring-after-installing-a-prius-off-road-lift-kit-gen-3-prius-1-5-inch-lift/
    and thus I released the sub frame spacers designed specifically for the Gen 3 Prius in February 2022
    https://black.jmyntrn.com/2022/02/10/the-fix-for-axle-rubbing-when-a-prius-is-lifted-1-5-inches-is-here/
    and so.. if this happens on all Gen 3's then why hasn't anyone mentioned this but me? so now have you, years later...
    now they want to release some half doohickey designed parts and call them sub frame spacers? you wont find another company out there selling sub frame spacers that do not make complete circle solid parts....
    https://black.jmyntrn.com/2024/12/28/why-subframe-spacers-are-essential-for-lifted-toyota-prius-models/
    lets not mention the Gen 2 and other sub frame spacer-related articles I've posted to get my thoughts out of my head and out there so others can see...
    you see, since because I raise flags and proved 1.5" was not the tallest you could lift a prius you wont find me in most groups on FB and just like your energy is coming across... for some reason I guess because Prius....lol I come across as unreliable. hilarious!
    unhinged as it may be, while others try to get matrix parts to work, from springs to sub frame spacers I've been ahead off the offroad guy while he and his goons try to silence me and promote my work through them. call it what you want but there is a large number of folks who see it just as I do. that said, I am open to suggestions as to not sound unhinged...
  17. James Analytic
    330
    52
    Michigan
    Back to Gen 2 Prius info. For the potential DIY Genuine make material K-frame spacers, I found a Vibe and Prius K-frame that looks as if no one is wanting. So most likely next time I'm at the yard, I'll cut those rear mount section tips off to measure for potential use as K-frame spacers for the rear two positions. I did today however grab all I could find regarding the strut washers on all the Gen 2 Priuses, Vibes and Matrix so I could compare and contrast a little. The AWD are excluded due to the design not having the feasible washer as a spacer part.
    Here is a bad overview video with enough info that I think is good enough to inspire and at the least remind me what is where.
    I'll try to measure when I next get around a Vernier or digital caliper. Thinking will be once I get the K-frame cut offs so can see what kind of washer stack with or without shims compared.
  18. James Analytic
    330
    52
    Michigan
    Not meaning to thread jack; though just found one of the best, if not the best, most cost effective DIY max lift for a gen 2 Prius. I like how Hybrid Garage used genuine stock materials for the front as I plan without welding to the actual strut. Wow!
  19. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    so uhm... I have a 3D scanner and can have pretty mush anything made these days... you wouldn't have to go through so much work as I have a dismantler who specializes in Prii but gets other things so, all i have to do is tell him what Im looking to 3D scan and I can. You could quarterback this to me and I have the ready made parts shipped to you. heh... I'm almost done with the Gen 2 AWD rear end.
  20. prius_newb66
    prius_newb66 Junior Member
    62
    17
    Chicago
    Hey guys, I’ve followed this thread for about a year as I’ve prepared to do this spring swap. You all have really done great, documenting all of this.
    My question is about the rear:
    I ordered two complete rear strut assemblies for a 2009 AWD Matrix and intend to move the spring and perch over, but I’m wondering if anything else can be moved over (besides, obviously, the spring and perch)?
    My current rear KYBs are pretty messed up, so when I have everything apart to swap in the Matrix springs / perch I also want to replace the rubber bushings at the top (KYB SM5382) + the strut bellows and bumpers (KYB SB132) — can any of these items be moved over from the Matrix AWD rear strut assembly or will I have to order the Prius specific refresher parts listed above to get it to work?
