Heavy Springs And Lift Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by strawbrad, Nov 24, 2019.
  1. Toddwilks
    Toddwilks Active Member
    555
    177
    Whitehouse Station, NJ
    Video is uploaded! Check it out!
    iPhone ?
    offib, donbright and 2Fats like this.
  2. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    Out of Stock already lol... awesome kit
  3. 2Fats
    2Fats Member
    101
    61
    Missouri
    I put off ordering a set, but I'll be getting one on standby in the next week or so. I talked to the "boss" about it, and we think it's a good investment.
  4. Toddwilks
    555
    177
    You won’t regret it. It’s a quality product, super easy to install and it makes such a difference.
    iPhone ?
    2Fats likes this.
  5. offib
    offib Member
    162
    95
    Dublin
    Four Touring
  6. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Can you tell us more about these "Valley Spring Works in California" springs you mentioned? Is it all 4 replacement springs?
  7. Toddwilks
    555
    177
    Interested as well. Maybe it’s better than the CSS helpers I was looking at on amazon.
    iPhone ?
  8. rickn11
    rickn11 New Member
    Northern Utah
    Four Touring
    New Prius Gen 2 owner here.
    Has anyone had success doing both the PriusOffroad spacers with the addition of the Vibe AWD springs in back and the Matrix springs up front?
    Would seem like this would work. I am ordering the spacers from PriusOffroad, but would also like to do the springs & struts while I am doing the work if it will actually work well.
    I want the stiffer springs to provide more cargo capacity for passengers, small trailer and roof rack.
    Thanks for your thoughts in advance.
    Prius Rising and offib like this.
  9. Toddwilks
    555
    177
    what’s the difference in spring rate compared to stock?
    iPad ?
  10. Toddwilks
    555
    177
    I love my gen2 kit. I’m installing another kit on my families gen 2 next week. You can watch my install video on YouTube under Whiteknuckle6.2
    iPad ?
    Prius Rising likes this.
  11. strawbrad
    953
    1,007
    OP here.
    My thread about heavy springs has been hijacked to talk about spacers. :mad:
    Spacers are great for ground clearance but will not increase the weight capacity. The heavy springs will increase the weight handling and add height clearance.
    I don't think spacers and the heavy springs will work together. I have tried both and either pushes the limits of the suspension travel.
    My heavy springs have been in for a year and work great.
    I have another project planned with a spring swap that should fall between the stock and AWD Matrix springs.
    Ol'Bert, Prius Rising, offib and 2 others like this.
  12. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I've got new KYB shocks and springs waiting to be installed with the lift spacer kit. Could you share a little more on your project in case I need to change direction?
  13. dolj
    dolj Senior Member
    8,442
    4,289
    Wellington, New Zealand
    Doesn't this thread do this?
    Prius Rising and strawbrad like this.
  14. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Re-read his post . The last sentence.
  15. Toddwilks
    555
    177
    You say the springs don’t fit and you have to add the spring perch from the matrix strut in the Prius strut. How did you get the perch off???
    iPhone ?
  16. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Post #10 above : Heavy Springs And Lift Upgrade | PriusChat
  17. strawbrad
    953
    1,007
    Post #20 has pictures showing the doubled perches.
  18. Toddwilks
    555
    177
    I saw the two just didn’t know how to remove one. I figured it was welded on.
    iPhone ?
  19. strawbrad
    953
    1,007
    Ol'Bert, offib and SFO like this.
  20. Toddwilks
    555
    177
    I just bought a set of tears to try this out off an 09 Vibe. Will be posting the process on my YouTube channel.
    iPhone ?
