Heavy Springs And Lift Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by strawbrad, Nov 24, 2019.
  1. Plaman
    Plaman Member
    46
    34
    Denver, CO
    Checking in. Have you made any progress? I'm probably going to try the Prius Overlanding spacers on the Matrix Spring (Prius Strut) assembly this week.
    2Fats, strawbrad and R-P like this.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Used tires?
    New tires are $100 each
  3. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Your naivete is showing.
    2Fats likes this.
  4. 2Fats
    2Fats Member
    101
    61
    Missouri
    No need to argue, used tires can be really nice and save you a lot of money. My last set of tires were 150.00 each, and the used ones I got for my pickup were 30 bucks each, and almost new.
    1prius and Prius Rising like this.
  5. Another
    1,819
    517
    Naples, Florida
    Your ignorance is showing
    Costco has them on sale for this every day
  6. 2Fats
    2Fats Member
    101
    61
    Missouri
    If it's not a big deal, I could use some new tires. Since ya'll seem to think it's not a huge thing to just buy tires, go ahead and send me a set. I'm not going to speak for someone else, but I bet black_jmyntrn would appreciate a set as well. TYIA.
    I looked on Costco to see tire prices. The nearest one is three hours away, and I have to sign a membership plan to get tires there. After all the fees, tires are just as expensive as anywhere else. (Lowest I found for my Pri was 140 Each.) Not everyone lives where things are available, and it's pretty crappy to attack someone for such a silly thing IMO.
  7. Another
    1,819
    517
    Naples, Florida
    That is correct. Distance matters. If you’re within their shopping radius, Costco deals are typically the best value especially when you get a nail in the sidewall and they replace the tire for free.
  8. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    this one time while in college I bought 4 used tires that barely had 1k miles on them since the previous owner replaced new wheels and tires with aftermarket ones. $40 a tire mounted and balanced/
  9. Another
    1,819
    517
    Naples, Florida
    In college, I once won a scratch off lotto ticket. Been trying to do that again but so far no luck.
    Amazon and Walmart e-commerce sites are good options to buy new tires anywhere you live.
    black_jmyntrn likes this.
  10. Plaman
    Plaman Member
    46
    34
    Denver, CO
    When did this turn into a thread about tires? Total shit posting.
    Used tires, brakes, and suspension can be perfectly fine if professionally inspected and installed.
    Just like new suspension, new tires, and new brakes can be deadly if installed by a moron.
    Keyboard warriors too busy arguing instead of wrenching-enough already. Sounds like nobody has yet to combine the suspension and spacer lift.
  11. Another
    1,819
    517
    Naples, Florida
    Your post is a great example
  12. dolj
    dolj Senior Member
    8,442
    4,289
    Wellington, New Zealand
    ... of bringing the thread back on to topic—Heavy Springs And Lift Upgrade.
    1prius, alftoy, Ol'Bert and 1 other person like this.
  13. Plaman
    Plaman Member
    46
    34
    Denver, CO
    You're right, let me put us back on track with this post.
    I have 1000 miles on the Matrix Spring / Prius Offroad Strut topper combo and don't have any issues so far. I will keep reporting back as the build wears in.
    Ol'Bert, Prius Rising and strawbrad like this.
  14. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Your profile says “other non-hybrid” as your car. have you fitted these Matrix springs to a Prius ?
  15. strawbrad
    953
    1,007
    Pictures?
    Please!
    Ol'Bert and Prius Rising like this.
  16. Plaman
    Plaman Member
    46
    34
    Denver, CO
    and then I put the Prius Offroad Strut Toppers ontop of that.
  17. Peter Stricklin
    Peter Stricklin Junior Member
    I joined the forum just to thank you guys for this thread. It was exactly what I was looking for for my 2005. I ended up buying some generic awd 2009 vibe strut assemblies and using the springs from them. The rear perches were welded on, so I cut them off and slid them onto my new prius struts. The tops were the same for both cars. I used new prius stuff with the vibe springs on the front. As stated before, the vibe struts are not a bolt in replacement for the prius ones. I measured about 1" lift in the front and 1.75" in the rear, but I expect it will settle a little. It rides well, if a little stiff in the rear. I'm really happy so far. It sits noticeably higher, and there are a couple areas I regularly travel that I no longer have to come at sideways. I am running 195/65r15 tires, but will go up when it's time to replace them.
    1prius, Ol'Bert, R-P and 2 others like this.
  18. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    I am all for a DIY route, sure... I have to use a Scion FRS Wheel Bearing & Hub Assembly for the rear of my AWD conversation and a Wilwood BBK for an FRS, but there is no "modifying" it. The modify suspension/brakes personally I tend to stay awa
  19. Peter Stricklin
    Are you OK? Did The Rabbit of Caerbannog get you?
    In all seriousness, what are your concerns with the matrix spring modification? Or does the concern lie in running both the lift and springs as it puts the suspension out of its factory range of motion?
  20. strawbrad
    953
    1,007
    Interesting statement to make next to a picture of a custom spring.
    Other than color and price that spring is very close to the stock AWD Matrix spring. This includes how both fit on the original Prius spring perch.
