Heavy Springs And Lift Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by strawbrad, Nov 24, 2019.
  1. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    R-P likes this.
  2. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
  3. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    Did you do anything different? (n)
  4. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    The above pics are before and after shots of the front and rear of the Prius.
  5. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    Also I forgot to mention I did the new springs/lift block method only I bought the knock off lift blocks from EBay for 150.00 rather than the 350.00 for the solid steel Prius off road blocks. Laugh all you want but polyurethane offers a softer ride than solid steel and at 200.00 less? (y)
  6. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
  7. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
  8. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
  9. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Long thread. I’ve forgotten, why are you doing this?
    Prius Rising likes this.
  10. Peter Stricklin
    Peter Stricklin Junior Member
    I cut my rear perches off just a little different so they slid right on after flattening the factory perch. I only eyeballed the alignment of the rear assembly, but I've done a lot of struts. Also, I had to buy a whole matrix assembly for the front and steal the springs.
  11. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    To document my Prius lift. o_O
  12. Another
    1,819
    517
    Naples, Florida
    What’s the need for the lift
  13. Peter Stricklin
    #safariallthethings
    In all seriousness, I did mine because the rear springs are heavier for when I'm full of camping gear. The lift aspect is a bonus, I no longer have to leave some of the places I go at an angle. Also there's a little peace of mind when driving down some of the campground roads we go to.
    Prius Rising and Another like this.
  14. Prius Rising
    Prius Rising Member
    152
    79
    Ohio
    So that I am able to travel down dirt/rocky roads without losing my oil pan in the process. If you go back and read the previous post's it's all there. (y)
    Simbaboy and R-P like this.
  15. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    actually a better one... making a kickstarter or other for a set of all four springs for the Gen 2, 3 and 4 that provide a 1" inch lift all around, debating on making the rear 1.5" inch. Thoughts?
  16. Peter Stricklin
    I would want my car to be level front and back which would probably be more like 2" front 1.5" rear :)
  17. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    level with or without a lift kit in addition to the springs?
  18. Another
    1,819
    517
    Naples, Florida
    If you raise the front more than the back, you’ll change the aerodynamics of the car.
  19. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    so ummm... I don't think you realize why Peter mentioned it... else your response wouldn't have been posted...
  20. Peter Stricklin
    I personally plan not to run spacers(prius offroad lift kit) and springs at the same time so my ideal situation would be a spring that lifted the car to a level position about 1.5" - 2" taller than it sits stock. I would think for most people this makes sense. Running both will require subframe spacers and a much bigger wheel/tire combination commitment.
