Heavy Traffic Draining Hybrid Battery
Discussion in 'Gen 2 Prius Fuel Economy' started by ChipotleBlkBean, Apr 14, 2011.
  1. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    YES the battery guage your looking at when it shows one bar left the battery has around 40% charge left. Don't worry and just drive. the car will not let the battery go below the 40%.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Yes, the car manages the battery state of charge (SoC). It likes to keep the battery at 6 bars.
    Low bars is not really low on the battery, it's just low on the range of charge. However, even within the safety margin the Prius uses, it's still worse for battery life if the car is doing a lot of deeper discharge cycles.
    At the end of my commute home I had the battery dropping constantly dropping to 2 or 3 bars because close to the end I have a couple of stretches of slight uphill at 25 and then 30 miles per hour and if I simply maintain constant speed the car would be under heavy EV use. To avoid that I use P&G, with the pulse under gas. If there are cars behind me I maintain speed by using frequent pulses. I now arrive home with the SoC at 4 to 6 bars.
  3. uart
    uart Senior Member
    4,220
    1,212
    Australia
    LOL PriusSport, that sounds more like a question that a newbie with one or two posts would write, rather than someone with over 1300 posts!
    When you're driving very slowly then yes it does try to keep the engine off as much as possible. But once it gets down to about two bars then it will always start the engine so there's no problem.
    mtbiker53 likes this.
  4. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    "Those are exactly the type of traffic conditions where plug-in's and full electric's are going to be an awesome advantage."
    Actually, I think this sort of situation is going to be the Achilles heel of electric cars. What do you think will happen when an electric car driver is stuck in traffic with an already drained battery, the lights are on, the AC needs to be running and maybe the wipers as well? That battery is going to drain fast as well! So you can turn off the AC and swelter, but who is going to be happy about that?
    I am no expert on electric cars, but I know the range is very limited and finding oneself in a huge traffic jam is with only a partial charge is going to be a challenge. Think about the electrically run devices you have used that suddenly lose their power, and usually this event is unpredictable.
  5. fuzzy1
    10,710
    I live in a different climate, and have no concept of needing AC for cooling simultaneously with lights or wipers. Needing AC for defogging, yes, but that is temporary.
    An hour of headlights should reduce EV range by less than a mile. Wipers shouldn't be any worse. The low speed of the traffic jam should make up for both. So the AC problem should stand by itself, not aggravated by the other fixed loads.
    A driver in trouble for encountering a traffic jam with an already drained battery was likely in trouble even without the traffic jam.
  6. bisco
    52,860
    same as a gas car with no gas.
  7. Viji
    Viji New Member
    Hi Folks,
    First time posting here. I have a 2008 Prius and Id been loving my car till last Sunday:) This happened when I was driving in SFO city on the Lombard street (uphill). It was bumper to bumper traffic and the car was going just fine, and at one point it just stopped and wont pull up. I had half+ tank of gas, battery was showing 4 bars, the car was ON (all electrics okay) but wont pull up even when pressing hard on the gas. There was a triangle warning light that came (system malfunction or something). I even restarted the whole thing, but no help.
    Finally AAA came and towed the car and brought it back to the normal road and it started running fine??
    Anyone knows what could have happened? My car service (dealer) says the battery (not the hybrid one) could be dead/low.
    Thanks
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    It sounds like the hybrid system went into safe mode aka limp mode. Did you also notice that the A/C stopped working? If so, that would pretty much confirm that the inverter is/was overheating due to a faulty inverter pump. Toyota issued a recall on the pumps earlier this year. Your car may be subject to that recall. I would check to make sure the inverter pump is working properly.
    Watch the following video, then check for the turbulence as demonstrated in the video. If NO turbulence, the pump is NOT working properly. The inverter pump should run ALL of the time when the Prius is in "Ready" mode.
    You can also check the voltage of the auxiliary battery with the MFD. There is a link to this procedure in my signature below. (Test the battery). It is a well known fact that a failing 12 volt battery can make the Prius do some strange things, but it is also possible that you have more than one problem.
    If you have access to a Toyota compliant scanner you should check for codes utilizing the OBD port since you mentioned the red triangle warning light. If you get a P0A93 code on the scanner, the inverter pump will more than likely be the problem.
    Luscious Garage | Blog | Prius Code P0A93: Inverter Water Pump Failure
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Exactly how to do it. Learn Warp Stealth, no arrows at all, just free rolling! Plan on it on downward slopes, feather uphill battery, regen when ever you can. Some of my best results have been on the Cal "5" heading to San Diego in really bad traffic. Upper 50's!
    For me that's killer!
  10. Viji
    Viji New Member
    Thanks a lot. I will check on the Inverter pump. I turned off the A/C when I was starting on the uphill, so didnt know the A/C stopping thing.
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Just FYI, a Red Triangle warning on a steep hill with no stored diagnostic code means low oil. Could have been so much drag inside the engine due to lack of lubrication that it wasn't developing any power. Check your oil. I know it sounds crazy.
    dorunron likes this.
  12. dorunron
    3,318
    1,105
    Houston, TX
    I should have mentioned that too, thanks for bringing that point up.
  13. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Don't forget to let us know your checks, repairs, and outcome for the benefit of the knowledge archive.
  14. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    I'm exhuming this thread because it matches a complaint I've had with the Gen 2 Prius ever since the first traffic jam I've had the misfortune of getting into with it.
    I will never buy another Prius because Toyota's engineers didn't make it possible for the driver to keep the ICE running when inching along during a traffic jam.
    I was in another bad one yesterday. It took over 30 minutes to drive 4 miles. The ICE was already warmed up when I got onto the Interstate and after a mile I ran into a huge back up. The next exit was 5 miles ahead - go figure.
    Naturally, the battery charge level dropped to the point when the ICE had to turn on to charge the HV pack but you never get enough time to charge it because as soon as you're moving you come to a stop again and the ICE shuts off again. So I did my best to keep the pack charged by revving the engine so it wouldn't shut off as best as I could which worked but was really annoying for my passengers who were getting whiplash from it.
    It would have been relatively easy for Toyota to include an ICE always on mode for situations like this. Just long enough to charge the pack to five or six bars would have done it.
  15. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jazz,
    You are overly concerned with the State-Of-Charge (SOC) of your HV battery. Your Prius manages the SOC just fine in traffic. The ICE only runs a short time when the SOC gets below 40% or when the CAT cools down below a threshold. When you get out of traffic, the SOC will get back up to 60-70% (5 or 6 bars) pretty quickly.
    JeffD
    srellim234, dorunron and Mendel Leisk like this.
  16. Tideland Prius
    16,681
    If the battery is low (2 bars... and I believe it has to be on the lower end of the 2 bars, not the at the level where it just dropped from 3 bars), that the engine will continue to idle even at a stop to charge the battery up to 3 bars. I know, since many a border crossings on long weekends were done in that scenario.
    Alternatively, leaving it in B will keep the engine running but I don't know if it'll actually charge the battery and if it does want to shut down the engine, it'll vibrate or shake like it's trying to shut down but the B mode isn't letting it do so.
    Lastly, you could've always force charge if you were really concerned.
    But like jdenenberg said, you're overly concerned about it. Don't worry and just drive it. You're basically asking a Prius to pollute more when it was designed to minimise the engine idling in case the traffic clears and you can have the battery charge up normally.
  17. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    The Prius was designed as an Super Ultra Low Emissions Vehicle (SULEV). It is doing exactly what it was designed to do. Minimise emissions in traffic jams, even after the HV Battery SoC drops.
    Don't worry about the HV Battery running low. This is neither a plugin, nor a full electric vehicle.
    Leave the energy levels of the HV Battery to the vehicles ECU. It does a brilliant job of protecting the battery while saving you fuel.
    Also take heart in the fact that other vehicles in that 30 minute 4 mile traffic jam must have expended far more energy and fuel overall, compared to the frugal Prius.
    I've occasionally been in similar snarl ups, but I've come to appreciate how the Prius handles them, even after the charge in the Traction Battery drops to purple. The battery will never be allowed to run out. There's always enough to smoothly start the ICE, compared to other cars with Stop Start Technology whose 12 volt batteries would have a hard time repeatedly starting engines in those conditions, over that length of time.
    Very impressive technology indeed - so much so, it's easy to believe conspiracy theories suggesting it was originally designed by extraterrestrials....
    iPhone ?
    srellim234 likes this.
  18. fuzzy1
    10,710
  19. Laura G.
    Laura G. Junior Member
    Thanks! I didn't know that-
    I thought the peripherals ran solely on the 12v.
  20. fuzzy1
    10,710
    They do run from the 12V. But that, in turn, is kept charged from the hybrid battery through an inverter.
    Data Daedalus likes this.
