heavy vibration of engine on idle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Umar Ali, Jun 8, 2015.
  1. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    So i replaced PCV Valve, i bought the genuine toyota from the dealer, it cost me around $11 and they had to order it. The engine is still very loud, this morning i was standing in patio and wife drove prius and i could clearly hear the loud engine noise. Dont know whatelse could be causing that issue. Engine is not running smooth either it is kind of rough.
  2. Patrick Wong
    18,204
    6,505
    Have you replaced the iridium spark plugs yet?
  3. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I have changed the spark plugs first, dont remember if they were iridium, i bought them at NAPA for $17 total of 4.
  4. Patrick Wong
    18,204
    6,505
    That is not helping your problem. Buy the correct iridium spark plugs, do not cheap out on this very important engine component. Only use the correct Denso plug as specified in the owner's manual, do not buy an incorrect iridium plug.
    Eventually if you don't resolve the engine problem, you are going to turn to a dealer tech or other professional mechanic, and the first thing they will do is inspect the spark plugs, tell you the wrong plugs are installed, and install the correct plugs at a big markup in parts price and labor. So do that work yourself, now.
    #44 Patrick Wong, Jul 11, 2015
  5. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I guess you are right since these were chep about $3 a piece whereas dealr quoted me for $16 a piece. Do i really have to buy from dealer or can i get somewhere else genuine toyota cheap one? asking since you really know alot i can tell from your responses :)
  6. Patrick Wong
    18,204
    6,505
    Umar Ali likes this.
  7. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
  8. Patrick Wong
    18,204
    6,505
    Yes, those plugs are not wonderful. Since you have an engine problem you need to rule out any possibilities, and this would be one. The correct plug is Denso, SC20HR11.
    Also, buy a spark plug gap gauge so that you can check the gap of the newly purchased iridium spark plugs. The correct gap is 1.0 to 1.1 mm. I set the new plugs to the narrow side of that spec, 1.0 mm.
  9. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    For my 2006 135k miles, I just replaced mine with NGK4996 LSR Irridium, (O'Reilly showed these as the OEM)
    $9.19/ea We gapped them at the store.
    Also cleaned out the MAV sensor and throttle body very well.
    Feels like the idle is a bit high since the install. Any ideas? Hard to tell what the norm is because I’ve only had it for a little over 2 weeks.
    #49 SDB54, Sep 16, 2019
  10. Patrick Wong
    18,204
    6,505
    Engine idle speed is computer controlled.
  11. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Maybe it’s running better/more like it should? Hard to tell because there’s no tachometer. Should probably give it a couple days. The throttlebody was pretty filthy, and who knows if and who cleaned it previously?
  12. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Still feels rough when the gas engine comes on and off sometimes, like the idle is too high or there's a dirty fuel filter, though I just read in another post that the fuel filter is in the gas tank, and can't be changed, so I guess I have to rule that out...
    Maybe I should run a couple tanks of the pricier gas and or add some STP fuel treatment, etc?
  13. Mendel Leisk
    41,402
    The fuel filter can be changed, but it's not easy, best left for later.
  14. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Maybe it's something else....? When the gas engine comes on and off it should be smooth yes? Haven't changed the PCV valve, maybe worth a shot.
  15. JC91006
    16,768
    8,565
    How are you determining the idle is too high? What's the car doing that's not right?
  16. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    As I mentioned, the engine idle is rough when the gas engine kicks on and off, like it's running too high. I feel like it should be smoother.
    I notice it more when I'm at a stop vs, when I'm driving and take my foot off the gas.
  17. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    When the ICE is on at standstill, it usually runs higher than idle, around 1300 rpm, because it is still warming up. If it is warm, it will shut down. When you're driving it will go down to 900-1000 rpm no problem.
