Height Challenged in a Volt
Discussion in 'GM Hybrids and EVs' started by iplug, Apr 20, 2016.
  1. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    The Volt is about 1 of 5 cars on the short list for our next car (wife's, actually). There are a lot of pluses with this car including best PHEV EV range, good price after fed + CA tax credits/rebates, decent ICE mpg, etc. - and it's available now. She has a ~25 mile round trip commute to work and unfortunately, though access to a 120 V wall plug there, works in a neighborhood where EVSE stuff is likely to disappear or be damaged if left alone to charge.
    My wife prefers a hatchback and is a bit nervous about the small potential to run out of juice and get stranded in a BEV. I told her if this happens, it is probably not of the cars doing. :)
    We went out to the Chevy dealership today to check out the new Volt, and noticed a big, or shall one say tall problem. At 6'2, I can't sit in the back seat without uncomfortably crouching my head down. I would be ok sitting up front in the passenger seat, but grandpa sometimes tags along and is 6'3 and our boys would push the rear seat limits in a few years.
    We plan on checking out the Prime, Bolt, and Leaf later this year. Thinking maybe could convince the wife to lease the Volt if it turns out to be a better fit otherwise then move on to the Tesla when it is readily available in the base trim level in a few years.
    Any other height challenged Volt families out there? What is your work-around? We would still have my Plug-in Prius as a backup for a while where grandpa and I still barely clear the headroom in the back.
  2. Toppcat
    Toppcat Member
    223
    69
    Northern California
    If you need rear passenger room, you need to look for some thing shape like a cracker box.
  3. Trollbait
    12,800
    Or a sedan, which is why the Model 3 is one, and even then it is still on the small side.
    I get the desire not to use any gas on the daily commute, but perhaps your wife should consider the Sonata, and likely Optima, PHEV, the Fusion Energi, or even C-max Energi if rear passenger space is important. I think you'll still find the Prime's rear head room cramped. The same will likely be so for any of the Ioniq models. Perhaps the Niro, but I'm not sure on Kia's plans with it in the US.
    The Leafe and Bolt are probably the only solutions for all electric commute with good rear passenger head room. Plus, they can get the better HOV sticker if that is a factor.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You're forgetting about the CMax Energi. TONS of headroom and very easy ingress/egress. Depending on the actual commute route, it might also make it on EV alone. It also has many options like powered liftgate, pano-roof, auto-wipers, auto-park, etc., that many of these others don't.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    That PiP is probably pretty darn good because Toyota shifted the hump of the car back there for Gen3...Gen4 the hump went more forward and they lowered the roof to look more like a sedan. Also likely we will not see as much cargo space as the PiP1 in a Plug-in "car" for some time. Minivan maybe with Chrysler.
    #5 wjtracy, Apr 21, 2016
    dbcassidy likes this.
  6. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    That was the starting decision point for us as well - enough EV range for a gas free commute. We will go look at the Sonata (which can do this) and and the Fusion (which won't make it), but she is pretty insistent on a hatch at this point. Maybe more headroom in the rear and 3 usable back seats here will be convincing. Thanks, going to checkout the C-max as well, but it's not gonna make it all EV either on her roundtrip commute without charging at work. Still, graduation from ICE alone is worth something here if this proves to be the best option.
    If the Prime's rear head room is the same as the Gen 4 lift back, we will be barely okay there. Its cramped, but I can just barely sit up straight with head contact on the ceiling. She's more concerned with the missing 5th seat and the horizontal bar that divides the hatch window/visibility in the back, so Prime may be out there.
    We will try these later this year. Hopefully can talk her out of the no ICE back-up anxiety.
    Definitely losing cargo space with the current affordable plug-in options. The PiP cargo room does get one spoiled. The Chrysler minivan will open up PHEVs for many more, but we're trying to maintain a marginal cool factor here, and our cars are primarily for commuting and we only have two kids, so holding off on the minivan option for now.
  7. Trollbait
    12,800
    If you aren't going to take the PHEV on trips outside of the commute that will use gas, I'd say go for the PHEV that will use a little gas on the commute but will better meets your other needs. 20 to 27 miles may not sound like much, but that is on every commute. Even with the 11ish miles of the PiP, people are going over a 1000 miles between trips to the gas station. Better to use the gas to move the car than to have it turn on the engine to just burn off the old stuff.
    Sounds like the Leaf with the small battery should meet her needs, but the Bolt's 200+ miles of range will go a long way to calming anxiety. From experience from the Sonic, it should work on head room, and the thinner front seat backs mean the legs not being crowded.
    What about the i3 REX, too pricey? The boxed off back side has promise for rear head room.
  8. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    The Leaf would work with some planning as a local/regional vehicle. Whereas I make largely short (<10 mile) and occasionally long trips (>200 mile) in my PiP, more frequently her work requires some medium range (50-100 mile) trips. The Leaf could be done with careful planning, though she prefers the "just get in and go" approach.
    If we got the Bolt, we would be able to forego my PiP on several long trips. We drive 1-2x a year the 400 mile drive down to Los Angeles and there are enough CHAdeMO stations along highway 99 to make this doable with a little planning. CHAdeMO isn't available in the Sierra where level-2 charging is sparse and inconvenient, so places like Yosemite and Sequoia would be risky.
    Headroom would be great, but yes - a bit pricey for the given EV range.
  9. Trollbait
    12,800
    I doubt the Bolt will have CHAdeMO, but will have whatever the frankenplug standard is officially called.
    The REX has an onboard range extender, but I personally would skip it if there wasn't a way around the hobbling dictated by CARB.
  10. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Looks like you are right.
    I did a quick look at PlugShare to see available DC charging stations by type. That would be a problem for long range trips as these seem less plentiful and one may run out of juice trying to go over the grapevine into the LA basin. For regional stuff, the 7.2 kW onboard L2 charger would be more than adequate for overnight charging.
    Not sure if a lot of folks will be able to use the Bolt exclusively for road transportation. Looks like the DC charging option will be extra too.
  11. Bigleftyinaz
    Bigleftyinaz Junior Member
    76
    San Antonio, TX
    You mentioned this car called prime. Who makes this? I tried to search but found nothing
  12. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    It's the new Plug_in Prius which is expected later in 2016
    Prius Prime Plug-in 2017 | PriusChat
  13. Bigleftyinaz
    76
    San Antonio, TX
    Thank you, finally found it. Fully is being kind
  14. bisco
    52,767
    kind to who?
  15. Bigleftyinaz
    76
    San Antonio, TX
    I see I got screwed by the auto correct and didn't pay attention to it. Suppose to say, fugly is being kind.
  16. bisco
    52,767
    but the cmax is a looker.:p
    #16 bisco, Jun 12, 2016
  17. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    OK Randy Johnson maybe try a RAV4 hybrid
