Hella Micro De Fog Light Retro-Fit
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Justdidit, Mar 7, 2013.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Been thinking about doing a retrofit on the fog lights as well since the Mini H1 Headlight Retro Fit went so well. Was considering the Blazer fogs because of 'F8Ls' upgrade.
    Some photos taken from here:FOG COMPARISON :: Hella, Blazer, Bosch, OEM Reflector
    But wasn't happy with the beam pattern as fog lights... but they make a GREAT driving light with a GREAT cut off...but no foreground for fog light use...but after seeing the light pattern from the Hella Micro De Fog Light - pretty sure this is what I'll use:
    Comparison of the light pattern - Blazer has awesome cutoff but barely any foreground:
    I'll like mount them in the yellow lens housing foglights to keep the look I already have:
    Retro fitting - Kinda like this - using a circle cutter or dremel to round out the back housing to mount the Hellas in the OEM fog light - thus retaining mounting points and aiming capability. I will be using a H3 3000k HID 55W setup with this
    (FYI...the above fog lights aren't mind or the oem 3" fog lights - this image was pulled from a Tacoma retrofit using 4" fog lights.)
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    OMG... these OEM fog lights... die cast housings are a PITA..to cut open.. this may take a new direction shortly.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    This is going to be nice. I admire your car
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Thanks!! Anyone can do what I'm doing...just gotta make time...and have a willingness to want to try and learn. This is my 1st Prius...
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Made more headway...
    Hella Micro De mounted with JBWELD to OEM cast aluminum fog light
    Chipped the glass lens while trying to separate the glass from the housing, ended up getting some .25" glass cut to 3.5" circles then coated them with 3 coats of Dupli-color Metalcast Yellow from TCPGlobal and 2 coats of clear spray paint to get the yellow lens look I wanted. Then resealed the lens with a waterproof silicone. You can see that the paint isn't 100% clear but doesn't stop the 3000k HID bulbs much. The good thing about doing the paint this way, I can remove the yellow paint at anytime in case I want to change the color of the bulb or lens and no longer have yellow fog lights but a 5000k driving light.
    H3 3000k HID bulb held in by (6) washers
    Because of the new length and size of fog light the bumper mounts for the oem bulb had to modifed and resized as well as a hole had to be opened behind the headlight for the length and the back of the HID bulb wires. This is a picture of roughly what was done with a dremel.
    OEM ---------------------------------------------------------Modified
    Installed
    Just need the adjust the aiming...will have that done hopefully this wknd.
    #7 Justdidit, May 29, 2013
    Daves09prius likes this.
  8. xTKxhom3r
    xTKxhom3r New Member
    San Antonio, texas
    man that turned out great bro i think ima follow in your foot steps
