Hello all,
Discussion in 'Gen 3 Prius Main Forum' started by Aftab Ak, May 15, 2019.
  1. Aftab Ak
    Aftab Ak Junior Member
    46
    Pakistan
    The cells he replaced were not brand new, he replaced used cells into the module pack. All other 26 cells were showing good decent voltages 7 I guess, the other two were 6.8 and 5.8 so he replaced these two.
    No idea what to do further, but for now it's okay.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Yeah I’m not saying they’re brand new, but if the new cells are from a 2015 and your 2011 cells are older, there is an age and most likely capacity difference ;).
    If the cells are from something older (say 2004-2009) it’s another potential issue. The only way to know is to have te serial numbers :).
    Are you the DIY type? If yes, then the Prolong equipment made by Hybrid Automotive might be up your alley for future work. If not and low miles, I’d look at @2k1Toaster ’s kit;).
    Hope that helps(y).
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    IF.......you really must keep the car much longer.......you should start shopping for a NEW battery or one that is completely rebuilt with all NEW cells. Or start shopping for a different car.
    As long as it is running OK there is no need to "fix" anything right now.
    Just be ready for when it fails again.
    There is an outside chance it could go a year or more.
    Aftab Ak likes this.
  4. Mendel Leisk
    42,355
    Just for the record: does disconnecting the 12 volt battery wipe all stored codes, or maybe just the display.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    All codes;).
    Those that are valid return :whistle:.
    But this method only kicks the can down the road(y).
