Hello Fellow Auto Enthusiasts..
Discussion in 'Newbie Forum' started by fdcapt, Nov 28, 2009.
  1. DaveFDEMS
    DaveFDEMS New Member
    97
    WI
    Evan those are not local polices. FDCapt and I provided many links earlier this week that showed them which you and certain members of your staff proceeded to delete citing the toyota ERG guide as gospel
  2. fuzzy1
    10,687
    Welcome back Dave,
    I have strong doubts that the thread was deleted due to the links you and FDCapt provided. The other thread content seemed much more culpable.
    Here are the links I managed to harvest from that thread before it vanished. Can you add any more links that I missed? I'll try to review the list later, from the perspective of an engineer in an unrelated industry.
    http://www.asde.net/%7Ebflorea/extrication%20safety%20notice.pdf
    EXTRICATION SAFETY - New Gas-Electric Vehicles and new Airbags
    http://www.drwenterprises.org/downloads/HybridVehiclePPE.pdf
    Emergency Responder Guide Lines
    Hybrid Vehicle Safety Hazards
    Hybrid Dangers - wtvr
    Hybrid Vehicle Training Program - Emergency Training Solutions, LLC
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Correct! Which is why they are universally color-coded orange
    Having spent close to 15 years in the petrochemical industry, yes, I am well aware that relays can fail or stick. Switches can also fail, perhaps the best example being the Ford cruise control cancel switch which was located on the brake line
    When the switch failed, it shorted, and the end result was a vehicle that burst into flames. If parked inside an attached garage, that means usually the house went up in flames too. Without a single high voltage hybrid battery system in sight
    Although a relay may stick, a fuse will often blow early. In the event of a dead short, with the relay stuck closed, fuses in the inverter/converter and in the battery can will blow
    Ok, I'll bite
    Hybrid Vehicles
    NFPA :: News & Publications :: NFPA Journal® :: November/December 2009 :: Features
    http://www.extrication.com/Hybrid Part-1 Ron Shaw.pdf
    http://www.extrication.com/Hybrid Part-2 Ron Shaw.pdf
    http://www.extrication.com/Hybrid Part-3 Ron Shaw.pdf
    http://www.extrication.com/Hybrid Part-4 Ron Shaw.pdf
    On the topic of vehicle safety, I wish more vehicles had an inertia cutoff for the electric fuel pump. In the event of a crash or a rollover, the fuel pump should immediately stop running!
    Having provided consulting on the dangers of common organophosphates and pesticides in rural agricultural areas, I'm convinced that there is a lot of misinformation out there. I have no problem providing training and risk awareness, but one thing that turns me right off is the bravado that some rescue workers feel that they have to show to an "outsider"
    Fine. I get paid whether they listen or goof off, and I sincerely intend for the audience to learn from the presentation. If they chose not to, they are the ones who will ultimately have to pay a price.
    Not me
    On the topic of high voltage safety, I have also given some lectures on this. My primary warning to anybody who has to respond to the scene of a crash, where utility lines are draped over the vehicle: assume the lines are live, or will soon be re-energized
    A lot of people are not aware that most MV and HV distribution uses fault protection in the form of a "recloser." The recloser cycle is based on what the needs of a utility company are. In an area with a lot of trees that may dangle limbs on a wire, you want a fairly quick reclose, say 15-25 secs, to re-energize and hopefully make the fault temporary
    In the case of other utility co's, they may set the reclose for 2-5 mins. If work is being done in the area, say trenching or adding a new line, they will lock out the recloser
    From what I have seen, most well trained rescue units are trained for at least basic HV safety, eg they have deadsticks (Non conductive plastic pole used to latch and unhook the manual circuit) and basic arc flash protection training and gear
    Here is an example of an arcflash event, caught by a security camera on an outdoor switch unit. WARNING: graphic content!
    Magna Electric - Video of Arc Flash Incident
    You will notice they almost instantly burst into flames? Arc flash events are horrific
  4. fdcapt
    fdcapt New Member
    ohio
    i will just say this.. nothing is fail safe.. things can will and do malfunction wether it be a relay a pyro charge or anything else man made for that matter....we as ems/emergency workers follow the standards and guidlines set forth for that very reason.. i see this turning into another mud slingin match quite fast... which is honestly the last thing we need.
    we have directives set forth by outside agencies such as nfpa and osha and many others. not much else to say
    Many of you are correct that there is a ton of misinformation out there.. but that as well works both ways... Be open to listen instead of try and refute every thing that is put out there.. research all avenues not the ones that seem fit to your point of view then draw a conclusion to your decision...
    I am not here to "challenge" anyone or try and refute anyones knowledge i am just here to provide what knowledge i can that i have gained over the years of my training and "real world" experience and hopefully learn some as well because in my profession knowledge is a must. Not everything you read in a bulletin or email or pamphlet is the golden rule.
  5. fdcapt
    fdcapt New Member
    ohio
    please tell me you meant this in jest...if not then please before you jump down my throat research what you just said... because itll be a cold day in h*** before i ever put one of my men in harms way because proper procedures were not followed. and just by following the procedures for a severe hybrid accident does cause some what of a time delay compared to a conventional "ice" vehicle.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Not in jest at all.
    I expect your men to follow proper procedure too. My point is that the procedures mentioned in your original posts are NOT proper, but rather drastic over reactions based upon overly cautious policy b/c of fear and poor information and research.
  7. fdcapt
    fdcapt New Member
    ohio
    im not gonna get into a debate on this because ultimately im sure ill get the ban button.... but for you to say MY policies are not proper is basically saying i dont know how to do my job....MY Policies and procedures are those that have been written and approved by people with a much higher degree of expertise then mine.. so before you make such a statement i ask that you again research what you just said.. the "proper procedures" we follow are correct and i believe your "expertise" may be somewhat jaded... so once again all i ask is that you actually research what MY job and My procedures are before you make a statement that they are improper.
    In your post you state that the procedures we follow are not proper... with what knowledge do you make this statement. what level of experience do you have? Where have you gotten this knowledge so i can direct my superiors to research what you are saying?
  8. efusco
    19,891
    1,196
    Nixa, MO
    Post your specific procedures and let me see them and address them specifically. You won't get banned here for expressing a civil honest opinion or facts. You will for being a smart nice person and trying to tell people that just b/c you have a job in EMS that you are an expert.
    A very quick google search shows that MOST EMS responders and locale's do not recommend ANY extraordinary measures when dealing with hybrids. Most are like the following that starts with this statement:
    [FONT=Arial,Helvetica,sans-serif][FONT=Times New Roman,Times,serif][FONT=Times New Roman,Times,serif]Today there are a lot of rumors, misunderstandings and misinformation out, about hybrid vehicles, that has created a great fear among emergency responders.[/FONT][/FONT][/FONT]
    [FONT=Times New Roman,Times,serif]During our research, we asked a question on many forum boards:[/FONT]
    [FONT=Times New Roman,Times,serif] "Has anyone responded to a hybrid vehicle accident?"[/FONT]
    [FONT=Times New Roman,Times,serif]We received many replies from departments that said: [/FONT]
    [FONT=Times New Roman,Times,serif]“We do not and will not do extraction on hybrid vehicles†[/FONT]
    [FONT=Times New Roman,Times,serif]This is unacceptable for emergency responders![/FONT][FONT=Times New Roman,Times,serif] [/FONT]
    [/FONT] [FONT=Arial,Helvetica,sans-serif] [FONT=Times New Roman,Times,serif]If we understand and practice a few safety measures. Hybrid Vehicles are no more of a risk than Conventional Vehicles.
    Hybrid Vehicles
    There are many many more like this out there. Well informed people who took the time to do real research and to educate themselves found that extraordinary measures are not needed, only minimal awareness and added precaution.
    [/FONT]
    [/FONT]
  9. fdcapt
    fdcapt New Member
    ohio
    added precautions alone as you stated is a time delay..... ive already posted a few direct sites to direct procedures on previous posts... im not gonna beat that dead horse but with a lil research to organizations such as nfpa and osha alone will render you a plethora of information on how to deal with a hybrid type vehicle.
    Im also going to take another thing you stated in that post and that is "minimal awareness" please tell me what minimal awareness means to you?.. that is a very generic statement.
    Lemme give you a prime example. Lets say lil joe shmoe from the local tiny township fd responds to a accident that requires extracation from a (insert any hybrid you wish). he then begins to the process of securing the patient for extracation. his partner (insert any name here) then begins the tedious job of cuttin the patient out of the vehicle. they do not have the proper training when dealing with the proper vehicle and now there are at least three patients but probably four do to the fact that the man with the jaws is also being assisted by another fd member. this was all because a hybrid CAN NOT be treated like your normal non hybrid vehicle. that is the only point i have been trying to make in all of this. Hybrid vehicles are a whole new entity in themselves and until all the "unknowns" are learned and improved upon it will be only natural for them to be treated differently and therefore be delays when handling them...
    When EMS extracation was started way back when they had these exact same issues with conventional vehicles... with time education and the willingness to learn im sure policies and procedures will change however for the time being we are fd/ems must follow the guidelines that are put forth by men and women making a whole lot more money than i.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Yes, I agree. Which is why proper training is necessary, proper training unfortunately is very time consuming and expensive
    Over my career, I have not only worked in petrochemicals, but on advanced fly-by-wire avionics for military aircraft and civilian airliners. As a design consultant and engineering consultant, its a bit daunting the level of misinformation out there
    Whether you are a First Responder, or a forensic accident reconstruction engineer, the goals are the same: ensure quick but safe response, try to figure out what went wrong, then ensure it never happens again
    As an example, a non fly-by-wire but still very advanced aircraft, a Boeing 767, experienced disturbing malfunctions while enroute from Schiphol airport in Amsterdam to the United States. Many of the advanced systems, including the display screens and autopilot, failed
    Upon landing, there was no reverse thrust, no spoiler deployment, and no anti-skid. As a result, the aircraft blew out all the tires due to locked wheels.
    The culprit? A loose shunt connection on the battery bus bar.
    NYC96IA116
    http://www.flightsafety.org/amb/amb_jan_feb99.pdf
    The moral of that story? No matter how well meaning or advanced the system, FOLLOW THE BASICS!! Which involves PROPER TRAINING, not anecdotal stories
    I searched around OSHA and NFPA. Came across this
    http://www.nfpa.org/assets/files/PDF/Research/FireSafetyVehicles.pdf
    Searched JEMS and came across this
    New Hybrid Respond Guide
    Reminds me of when airbags first became mandated. There was a huge amount of misinformation out there. Although hybrid vehicles now make up a minor proportion of total vehicle sales, in the future they will potentially become common
    Just as we had to adjust to power steering, fuel injection (Ever get caught "pumping" the gas pedal when fuel injection first came out? I did, hard habit to break!), ABS, and airbags, we will have to adjust and learn about hybrid technology too
    Yes, that is a two-way street. As an engineer, I always keep an open mind.
    But .... and this is a rather large "but" .... I can't make up s*** to suit my own agenda. Every thing I do, every little f***ing thing, I have to document, test, retest, PROVE, and then - finally - submit to my peers for review
    Even then, if my peers think I am full of s***, it goes nowhere. Welcome to the world of engineers! Folks wonder why even basic research seems to take forever, that is why
    So, if you have something that is genuinely of a concern, it should be properly documented in proper channels, eg the "chain of command." But unless I missed something, the official channels claim the hybrid "fear" is based more on lack of knowledge, than on fact
    When that bulletin or email is from a credible and official source, at what point do we ignore it and try to wing it?
    It's like what I tell folks when they piss and moan about Microsoft: "If you don't like Windows, feel free to create a better operating system, put your name on it, and sell it. It's a free country, you can do that, you know"
    Using engineering as an example, do I make things up, or do I follow credible sources like the CRC Handbook? Obviously, I have to follow the established and credible sources
    There appears to be a lot of contradiction among some of the sources. Could you please cite examples? Preferably without heated dialog
    Well, in my case, I have a degree in chemical engineering and a degree in computer science. I recently shifted my consulting from petrochemicals to Federal agencies
    Among other endeavours, have provided consulting to Federal agencies on Critical Infrastructure protection, and the terrorism threat from agribusiness, eg the relative ease of obtaining organophosphates.
    I'm not going to get into why that is such a concern. I'm sure you're well aware of the risk, at least you should be.
    Yes, with any new vehicle, gone are the days of "simple" extractions. One must contend with highly computerized vehicles, that may or may not be "off" when you expect them to be. Electric fuel pumps may keep running, pumping fuel over a hot motor
    Airbags built into the seats and headliner may or may not deploy once you start removing a roof to extract a trapped patient. Due to the times we live in, there may or may not be a potential chemical threat inside, eg organophosphates.
    Also, due to the times we live in, more and more nondescript vehicles may be equipped with very advanced offensive and defensive systems, used by VIP transport:
    Chevy Suburban 2008 with armored bumper
    They appear to be telling us that proper training is essential
    I completely agree. Just as airbags added an entirely new level of danger, until proper understanding and training dealt with that. I have no doubt a large city rescue crew has had proper training.
    But the small "backwater" county unit may not have. Even with grants, that training is far from cheap
    But proper training is essential, I'm sure you will agree with that. Just as I find myself constantly being updated on new technology, you must be too
    Unfortunately, I have felt that after providing lectures on proper chemical agent safety and handling, the majority of the audience simply didn't care
    Did I just have a bad crowd? Or is this the norm?
    I have consistently received very positive feedback from my peers regarding the quality, depth, and concise nature of my presentations.
    Why is it that fellow engineers have no problem asking me questions, or seeking clarification on a point, but those in rescue work do not?
  11. fdcapt
    fdcapt New Member
    ohio
    Jayman i can not and will not refute pretty much anything you said... you are spot on with about everything i have been tryin to say from the beginning..
    As for the rescue workers not being as open to receive your training and messages all i can say is you have to take that for what it is worth... you always have a percentage of people in all communities that are the "know all be all crowd" and im sure in their closed minds they are thinking "what is this book smart engineer gonna teach me that i dont already know". and those are the same people that get folks hurt and/or killed. Those are the ones when i am instructing a class i let weed themselves out and i focus on the ones who are genuinely trying to better themselves and learn. Kinda goes back to the saying, old habits are hard to break.
    On a side note how do you like your fj.... i have been lookin at them very seriously and almost bought one when i bought my truck (was between an fj, f-250 and a range rover). They are a lil small for me but would still be a very useful vehicle in my line of work, and i think they are a super nice lookin vehicle.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    If they refuse to listen, well, they have to pay the price in the end
    Very satisfied with it. Just myself in it usually. Purchased originally as a second vehicle to drive out to my hobby farm, which for the 97 miles was all pavement except the last 2 miles. Those last 2 miles were pretty bad
    I had 160 acres next to Crown land, where a cutting operation started up a couple of years ago. The road really became bad, the FJ ground clearance was absolutely essential
    A co-worker recently bought that property. I had 320 acres vacant land much closer to where I live, only 30 miles, but half of that is on gravel roads. Some of the roads aren't even maintained in winter, so I need a 4x4 more than ever
    For winter, I now run factory-studded Nokian winter tires on it. I never use 4H on public roads. This is from a surprise ice/snow storm back in October
    A closeup of the studded tires
    Their website
    Nokian Hakkapeliitta 5 SUV
    I had always assumed a stud was a stud. The factory studded Nokians have a special square design, their grip on glare ice is amazing
    My vehicle business travel is very much reduced now, but its easier to write off a multipurpose vehicle up here than a passenger car.
