hello for everone im from ukraine odessa
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by serdar, Mar 7, 2019.
  1. serdar
    serdar New Member
    ukraine odessa
    hello im form ukraine odessa i have a question about my plug in 2012
    i check is with obd2 today morning and i saw on the program my battery have some different vl
    i add the picture plse help me this is normal or not
    car is without charge now and last charge my range was 9 mil
    thanks for all answer
    52,820
    welcome!
    i'm not sure what those last couple of values means. try the service manual at tech info.toyota.com
    all the best!(y)
    serdar likes this.
  3. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I think there's only 8 blocks in the Gen 1 Plug-in, so the blocks shown after 8 is probably false data.
    The Hybrid Assistant app "battery health check" can probably give you more useful data, but the app developers do not have a test procedure for the Plug-in.
    9 miles estimated on a full charge isn't totally out of the ordinary, especially in a colder climate.
    Some things I would suggest:
    • Check all the brake caliper slide pins are moving freely and lubricate them or replace if seized/heavily corroded
    • You can safely block 100% of the lower grille in winter to reduce fuel consumption (there's a detailed thread somewhere about Gen 3 grille blocking)
    bisco, serdar and jerrymildred like this.
  4. serdar
    serdar New Member
    ukraine odessa
    hi huys thanks for answer today after charging i check it
    picture i add
  5. bisco
    52,820
    Looks like you’re good to go!
  6. serdar
    serdar New Member
    ukraine odessa
    sorry i litle dont understand (
  7. bisco
    52,820
    if the first 8 are the only modules, they are good, and the rest don't matter
    serdar likes this.
  8. serdar
    serdar New Member
    ukraine odessa
    nobody havent any ideas?
  9. QuantumFireball
    420
    269
    Ireland
    The voltages look OK. There are only 8 blocks in this battery - ignore 9-14 because they don't exist.
    See my other post regarding loss in EV range.
    serdar likes this.
  10. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    bisco :
    American English saying. Means that all is ready, all is prepared, you can start any time you like, even right now.
    bisco and serdar like this.
  11. rahhal.ayyat
    rahhal.ayyat Junior Member
    JO
    serdar likes this.
  12. rahhal.ayyat
    JO
    Its normal and in a good condition
    serdar likes this.
  13. serdar
    serdar New Member
    ukraine odessa
  14. QuantumFireball
    420
    269
    Ireland
    That's Torque, but it requires a lot of effort to configure it like that.
    Hybrid Assistant or Dr. Prius will give you live battery monitoring out of the box.
    serdar likes this.
