Hello my name is Ian. I'm new. Can someone please help if they have time.
Discussion in 'Gen 2 Prius Technical Discussion' started by Ian Simons, Jul 19, 2016.
  1. Ian Simons
    Ian Simons Junior Member
    48
    Lake arrowhead
    Chime - Red exclamation light - red thermometer icon . I had this problem today. I live on a montain like 5000ft and go up and down it regurlay. This has never happened. I heard something about bleeding the air and changing the coolant but i don't fully understand fully. I have a small learning incapability but i'm not stupid. Can someone help explain this to me in the easiest way possible?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Welcome to PriusChat.
    Sounds like you think it may be overheating.
    It may not be a bleeding issue?
    I would say to start with the basics and first confirm whether you have enough coolant as well as enough oil.
  3. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    The Gen2 water pump can leak out the antifreeze so you have to add more fluid.
    There is special pink Toyota Super Long Life Coolant you must use.
    Also of course check to make sure your fan belts are in good condition.
    49,434
    welcome to priuschat, all the best!(y)
  5. Dragon Rider
    Dragon Rider Active Member
    344
    211
    Miami
    Check the Radiator and the hose too. Could be the water pump. Good luck.
  6. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    As others have stated - first things to check are your radiator fluid level and oil level. Also make sure there is not any debris/objects blocking air from coming into your radiator. If there is not an obvious fluid level problem, go to an auto store that will read OBD codes for free - Auto-Zone will do this. The codes they provide will come with a description. Most likely you'll get code(s) related to overheating, and from there the codes can be used to diagnose what the problem with your car is. Post them to this forum and we'll help you figure it out :)
