Hello! Relatively sane newb/wannabe PC w/?
Discussion in 'Newbie Forum' started by CrusinSusan, Feb 25, 2012.
  1. CrusinSusan
    CrusinSusan New Member
    Fl
    So! I'm liking the up-coming Pc and know little to nothing about Hybrids; but I came across the blog of a woman who uses her Prius to camp in (think her site was Prius RV or some-such), and she said that she can keep the AC/heat on all night long.
    Is this also true of the soon-to-be-here Prius C? Can the AC or heat run all night without issue?
    Thanks in advance.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard Susan!
    Sure you can do that, but the engine has to run to produce the heat and eventually power for the AC. It just has to run the engine less than a conventional.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Yes, in truth any vehicle can do this but the Prius has the advantage of using less fuel to do so. The drawback is that you can hear the engine turn off and on so if you are a very light sleeper then it may wake you.
    The GenII and GenIII Prius is large enough to contain a twin-size mattress so it makes camping very comfortable. The Prius v would be even better due to the tall roof instead of the sloping roof of the lift back models.
  4. CrusinSusan
    Fl
    Thanks ! But just to make sure I understand,....am I correct in assuming that the car does NOT have to run all night to have heat or AC? It turns itself on and off?
    And yes, I know nearly any other Prius would offer more room, but frankly, I'm trying to keep costs down...and I'm not keen on buying used.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The car will be READY all night and in Park. The engine will run about 1 minute in 9 for A/C. Heat will make it run more as uses waste heat from the radiator.
  6. richard schumacher
    7,686
    1,067
    United States
    You will go to sleep with the car ON ("Ready") exactly as though you were about to drive it, except it will be shifted to Park and you will have the parking brake set. No worries. Just start with at least half a tank of gas, and do not park near anything flammable (dry grass, pine needles, etc.).
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The car's 'on', but not running all the time like a conventional car would be. When the battery is depleted to a certain point, the engine runs to recharge it, and then turns off. I've used this useful feature when camping, but only for a few small accessories like a food cooler, not for air conditioning. I've found the engine runs a few minutes every hour, but it would likely run more often for higher loads.
    But....it's really not an environmentally friendly thing to do. The mileage of a mobile gas-powered fridge is terrible. Maybe if you parked in the shade, near a stream....or camped further North? :)
  8. CrusinSusan
    Fl
    Thank you all! But I have another question....will this also be the case for the lighter adapter? So that if I want to charge my laptop while NOT driving, I won't deplete the battery if I leave it on and in park?
    And yes, I know it's not environmentally friendly, but it still would beat the heck out of my 15 mpg van right now.
  9. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Basically, yes... Most cars tend to disable the 12v lighter socket while the car is off, so you will need the car to be 'on'. Although, I would not recommend doing that, cause if I recall correctly, you will need the key to be near the car for it to stay on, I think. (I could be wrong though).
  10. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    The answers above apply to any electrical accessory you want to use, just leave the car in Ready and the computers in the car will take care of it.;)
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You only need the 'key' to restart the Prius, it will stay READY so long as you have fuel.
  12. Keiichi
    808
    79
    Goleta
    I stand corrected then.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    You can also run standard 110V electric products from a parked Prius, such as a small refrigerator, portable lighting, computers, etc. For small items, like a laptop, you can buy a 12 volt inverter that plugs into the cigarette lighter. For larger loads, you can buy an inverter of 900 watts, which you attach directly to the 12V battery. For either to work, the car ignition must be On. This is a great way to supply emergency power, a full tank of gas can last several days to a week.
  14. CrusinSusan
    Fl
    The most powerful thing I need to run is the laptop, and I have an inverter for that....soooo....
    (cue music)
    "I'm in heaaaaavvven....I'm in heaaaavvven..."
