Help 06 prius with multiple codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hurricane, Jul 12, 2018.
  1. Hurricane
    Hurricane New Member
    Hamilton
    Hi new to the forums world and to this site. I have a 2006 prius with about 277k on it. Recently it gave the red triangle of doom along with the check engine light and the yellow exclamation point. I plugged in my habor fright scanner and got these codes p0a78 p0a80 c1378 c1259 c1310. I also looked at the freeze frame and those gave p0a78 and p3012. I was hoping someone can point me to a good starting point to diagnose and repair or if i should just sell it due to cost of repairs. Thanks for any insight.
  2. Patrick Wong
    18,200
    6,479
    Replace the high voltage traction battery.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,335
    6,011
    Columbia, SC
    Hurricane, where are you located?
    49,708
    diy or dealer service?
  5. Hurricane
    Hamilton
    Thanks for the replies. Would the traction battery replacement solve all of the the codes or is that the place to start? I plan on doing this myself. I am located in Hamilton, Ohio.
  6. Patrick Wong
    18,200
    6,479
    A great question. DTC P0A80 and P3012 indicate that the traction battery has failed and also pinpoints the second module pair to be at fault.
    DTC P0A78 points to a problem with the inverter, transaxle or hybrid vehicle ECU (depending upon which three-digit subcode is logged). You need Toyota Techstream to have visibility to the subcode.
    DTC C1378 points out a problem with the backup brake power supply which is a capacitor bank located next to the 12V battery.
    My guess is that these three problems did not simultaneously occur; rather you have been living with one or more of these issues for a while. You'll have to say whether this is true or not.
    Considering the odometer reading of the car, I would say that it might be time to take it to the salvage yard. You likely will have to spend much more than the current market value of the car to remedy these three issues.
