HELP - 12v battery on backorder
Discussion in 'Prime Main Forum (2017-2022)' started by Maria Lee, Dec 7, 2021.
Tags:
  1. Maria Lee
    Maria Lee New Member
    I have a 2017 Prius Prime plugin advance. It's been sitting at home for a while due to the pandemic. I just found its 12v battery is dead. I had to jump start my car. It won't charge even after driving on freeway for 40 mins. I just called my dealership and they told me there is a national shortage on this new 12v battery and I have to wait for 6 months to get a replacement. I called my local auto shop and was told similar things. BTW, I'm in SF bay area.
    I'd like to drive my car ASAP for a trip. Does anybody know where to get a new 12v battery for 2017 Prius Prime plugin advance? TIA!!
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    That’s not the original battery size, known in various designation systems as LN1, H4, or 140R.
    This is the correct one from NAPA: https://www.napaonline.com/en/p/BAT75140R
    That’s really not enough time to recharge a deeply-discharged auxiliary (12-volt) battery. I’d suggest putting the battery on a charger for a while, if possible, to give it a fair chance to recover, before deciding that it has to be replaced. Chargers for lead-acid automotive batteries aren’t expensive, and you might want one, anyway: if you leave the car parked again for a while, a new battery is likely to discharge in the same way.
    If you must have a new battery today, you could try the AutoZone store at 1818 Hillsdale Avenue in San Jose; they supposedly have an H4-DLG battery in stock, which is also the correct size for your car.
    vvillovv and Mendel Leisk like this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
  5. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Too bad I didn't see this before I turned my old battery in for a core charge credit. It was still good.
    Try Carquest auto parts. That's the only place I could find one in the SF Bay Area. The dealer wouldn't even order me one.
  6. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    My battery died yesterday. I picked one up at Advance Auto for $180. It looked the same as the Napa battery:
    The Advance Auto battery fit perfectly and I'm on the road again.
    My 2017 Prius Prime battery was 5 years old and hasn't been sitting for any length of time. Maybe it could have been recharged but probably not.
  7. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    They were telling me that back in 2018, so it may not necessarily be related to Covid. In fact, the dealership had put one on order for me and Toyota USA canceled the order.
  8. Maria Lee
    May I please have the link to your Advance Auto battery?
    I just called them and they said none in stock nearby. But thanks anyway for the tip!
    Just called Carquest auto parts and none in stock. Thanks anyway!!
    #8 Maria Lee, Dec 8, 2021
  9. MikeDee
    1,581
    597
    Advance Auto = Carquest. The website says in stock at the Manteca store. This may be the only choice in the greater Bay Area. I'd give them a call. View attachment 220011
  10. Maria Lee
    Thank you so much!! I found ppl here so much more helpful than the horrible Toyota service. They don't care and a waste of time.
    douglasjre likes this.
  11. Maria Lee
    Has anybody found problem with pumping gas into their car once their 12V battery is dead?
  12. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Yeah, it's a bit of a bummer. There aren't a lot of places that carry this form factor, and some Toyota dealers are reporting no stock and some delays. This is timely for me because I think my battery is on the way out -- a few days ago I kept the car in accessory mode for maybe 10 minutes, and then for the first time I got the dreaded "12 volt battery low" message that couldn't start the hybrid system. I was able to charge it and put a maintainer on it and it's somewhat better but still weak, so I will probably replace the battery anyway. I called the local dealer's parts department (only one within 70 miles) and they had one left, and they said they'd hold it for me for a few days while I see how much I can resurrect it. Most likely I will get it in a couple days, since I don't know how much I trust this moving forward even if most indications are that it's a little more stable now -- especially since stock is so scarce now, I may just buy it now where I might otherwise wait a while.
  13. MikeDee
    1,581
    597
    I'd buy a new one, since they are in short supply and you don't want to get stuck somewhere. IMO, you can't revive a bad battery. Also, the dealer battery has less CCA's than aftermarket ones (295 vs. 480 for the one I bought).
  14. PiPLosAngeles
    1,551
    724
    There's something going on with the Gen 4 and 12V battery maintenance. My 2018 battery was always around 11.8V. The dealership wanted to replace it and Toyota USA blocked them from doing so.
    I'm not sure CCA is an important factor in the Gen 4 battery issues. It seems as though chronic voltage <12V is common in these vehicles. Generally, a low state of charge in lead-acid batteries induces sulfation on the plates. This sulfation can become permanent and the battery capacity is reduced. CCA can be maintained even while capacity is severely diminished, so it's not an indicator of capacity.
  15. PiPLosAngeles
    1,551
    724
    I hadn't checked my PP's 12V battery until this thread got me curious. Right now it's sitting at 12.05V, which is low enough to encourage sulfation. Lead-acid batteries are supposed to be maintained above ~12.4V. It's only been sitting for ~36 hours, when it was driven for a couple of hours.
    EDIT: I think it's relevant to note that my 2012 PiP still has the original OEM 12V battery and no sign of issues so far. Are the PP's lasting as long? It doesn't seem like it.
  16. Mendel Leisk
    42,347
    Increases in CCA usually comes at expense of amp hours though. Out of my depth, but I’ve heard higher CCA requires more/thinner plates, and that leads to the trade-off.
  17. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    CCA is hardly an issue for a hybrid. The current draw during "start-up" isn't very high.
  18. CharlesH
    2,798
    1,166
    Roseville, CA
    Yeah, booting up the ECU's is not exactly a high current action. I understand that 8 D cells (to get 12V) works just fine.
  19. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Yeah, I did. Picked it up this morning and will install soon. With a full maintenance charge the old battery is holding a better voltage, but still getting iffy. It’s holding 12.3 volts now instead of 12.1, but I don’t trust it too much.
    For a hybrid, I think fewer CCA is fine, and arguably better.
  20. MikeDee
    1,581
    597
    Well, the the new battery was noticeably heavier than the old one. I would think that would relate to capacity, but don't know.
