Help ! 2006 Prius - starts and dies after 15 seconds
Discussion in 'Gen 2 Prius Fuel Economy' started by ikefor, Aug 8, 2016.
  1. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    A friend's 2006 is giving some trouble and i would really love some help from the techies here.
    HV battery changed over 4 months ago and car ran fine until last week when the car just stopped and won't get ready. Before that incident, the vehicle was running fine all day, while he was returning from the days chores in the evening, it just stopped, dashboard all lit up.
    After a while, the car started again, and he was able to move it away to the side of the road...just about 2 meters and it stopped again.
    When i got to him, i pulled some codes using techstream
    P0A0F
    P3000
    P3190
    P0A80
    C1242
    C1259
    C1310
    Could this really be a HV battery issue?
    He changed the 12v battery and the situation did not change.
    When the vehicle is put to ready, it temporarily goes on ready for about 10 to 15 seconds, then you get this engine noise as if the ICE has just come on, then it then shuts down.
    I read somewhere that even though you get to hear that engine sound, it does not mean that the ICE is engaged.
    Well, went ahead to clean the maf sensor (with some maf sensor cleaner), the intake manifold and changed the plugs. Still the same.
    At this point, i may be heading to the HV battery. Any comments will be appreciated.
      File size:
      125.1 KB
      File size:
      216.6 KB
      File size:
      191.6 KB
      File size:
      130.2 KB
      File size:
      153.7 KB
      File size:
      155.5 KB
    #1 ikefor, Aug 8, 2016
  2. JC91006
    16,933
    8,643
    yes, at a minimum, it points to a hybrid battery failure
    52,786
    who changed the hv battery, and what brand?
  4. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Dorman originally, it failed after 18 months of use. I reinstalled it after changing HV battery ECU, wireframe no 2 (old ones where toast), some module changes and balancing.
  5. bisco
    52,786
    could be it then, i suppose.
  6. JC91006
    16,933
    8,643
    You should return to Dorman......that battery ECU is also under warranty, you should not have to mess with it.
  7. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    yes, i was thinking so too but i wanted to get opinions especially since the car goes ready....i would expect that the car will not get ready at all with a HV battery failure.
  8. JC91006
    16,933
    8,643
    P0A80 code means you have a battery failure
  9. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Yes JC91006, that was a decision that we had to make....living in sub sahara Africa, you can appreciate what it takes to get a Dorman battery incountry. Owner was not interested in going that route anymore ......
  10. JC91006
    16,933
    8,643
    I actually think your issue right now is you ran out of gas. Try putting 5 gallons of fuel in the car and go from there. Make sure it's 5 gallons or more, no less
  11. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    yes, owner concurred that car may have run out of gas at some point, we went ahead and put in some gas....i actually don't know how much gas was put in the vehicle ..... will check with him and ask him to go ahead and add more gas to at least 5 gallons
  12. JC91006
    16,933
    8,643
    The car will not register the fuel if you don't put 5 gallons in. Most owners put in 1 or 2 gallons and the car won't register that fuel. So try to add at least 3 more gallons
  13. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Ok, will do that and revert ....you are absolutely right, i know for a fact that what was put was not upto 5 gallons.
  14. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Ok, we put in some fuel till at least more than 5 gallons and the car did the same thing ..... Ready for about 15 secs and died.....sadly!!!
    Still looking out for a positive solution before I make a decision to head toward the battery .....
    I also changed the battery ECU with a known good same part no and it was same !
  15. JC91006
    16,933
    8,643
    Try and reset the car, disconnect the 12v battery for about a minute and reconnect. Then try to restart
  16. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Ok will try that as well..and get back.........
  17. Vonecut
    Vonecut Junior Member
    Baltimore maryland
    I had the same codes and problem after one year with a new hybrid battery. I thought the worse..... Turned out to be a wasp got stuck in the sensor in throttle body cavity.
