HELP! ABS pump went out Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by erick vazquez aguirre, Mar 1, 2019.
  1. erick vazquez aguirre
    erick vazquez aguirre Junior Member
    Venice, FL
    Hey guys i got a Prius V , the Abs pump went out , still able to brake but my dash is all lit up and the pump beeps every 3 seconds. Dealer wants $2000 for the repair $1400 for brake assembly and $600 for labor , they dont sell just the pump you have to buy whole assembly i guess. I am very mechanically inclined and was wondering if i can replace this pump myself if got a used one like on ebay or would i need to have techstream for some reason to activate the pump or bleed the brakes? Thank you
  2. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    Starting to see more of these.... Not good.
    How many miles and (initial pressurization) start-up cycles?
    #2 Air_Boss, Mar 1, 2019
  3. erick vazquez aguirre
    Venice, FL
    115,000 miles, my abs is gone . Can i buy another used pump and swap it ? or would i need to bleed brakes , activate it with some speciual software . Made a complaint to the NHTSA and also to toyota
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Tech stream necessary
  5. erick vazquez aguirre
    Venice, FL
    techstream necessary for what , to activate it ?
  6. tankyuong
    1,555
    662
    Central MO
    Yo cycle the pump
