Help! Accidentally let all fluid drain from rear drum brake line and bleeding won’t refill it.
Discussion in 'Gen 2 Prius Technical Discussion' started by PriusThatTows, Oct 24, 2020.
  1. PriusThatTows
    PriusThatTows Junior Member
    Colorado
    Touring + Tech
    I was trying to replace drums and didn’t pinch off the brake line. The baggie i ziptied to the line has like a pint of brake fluid. I thought, “No big deal. I’ll just fill reservoir and bleed it all through”, but that isn’t working. I am getting a tiny trickle of fluid out the bleeder valve and into my homemade bleeder bottle setup. I’m hoping its a simple issue like gunk is clogging the line in the wheelwell and I can cut, flare, and attach a flexible line... or perhaps in moving the line out of the way I kinked it which could be fixed the same way. But... I’m worried that draining the line all the way back to the master cylinder might have damaged something. I know that the master cylinder/abs assembly is over $1000 and multiple hours to replace.
    Is there some obvious reason it might not be bleeding that I’m missing? I’ve tried “pump, open, close, release” like 50 times now.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Unless you have techstream handy, try the "prius rock" method for bleeding the rears.
    100K maint - 1
    Raytheeagle likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Assuming that it has ABS, there likely is a somewhat more complicated procedure required to get it to actually send fluid to each wheel when the car is not moving.
  4. ChapmanF
    18,733
    Are you trying to bleed without using the Techstream procedure?
    I think if the system detects an unreasonable amount of fluid going down one brake line, it will leave that line valved off to avoid losing all braking, and that will prevent most faux bleeding methods from working.
    Herman Munster likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,104
    2,006
    NJ-USA
    On the prius, the brake actuator completely controls the brakes. When you normally step on the pedal the computers decide how much regeneration to do first, then it uses a pump to make pressure to work the brakes at each wheel. Your foot has no direct connection to the calipers or wheel cylinders. IF the actuator completely fails then there is a backup mode where the master cylinder will directly connect to each of the front brakes- you still have some braking but no boost.
    The front brakes can be partially bled using a pressure bleeder or some other manual procedure, but the rears require a scantool (techstream) or another way to tell the brake actuator to apply and send fluid to the rear brakes. There may be "work around" methods for this on youtube but I have never tried any. You also need a scantool when you have to fully bleed the actuator.
  6. ChapmanF
    18,733
    A brake rock works for the rears, if the brake ECU hasn't already declared that line off-limits.
  7. Herman Munster
    Herman Munster New Member
    Apex, North Carolina
    Dear All... I just went through this issue with my 2004 Prius. The short story is that I had to clear all the DTCs (trouble codes) before the system/ABS/Actuator would allow me to properly bleed the right rear drum brake.
    I used Toyota Techstream software and cable (DIAGKING) to clear the DTCs and THEN ran the “Usual air bleed” utility to bleed the system. One of the many confusing things is that when the system has detected the large leak of fluid, and shuts off flow to that line, it still allows a small amount of fluid (a decent drip, drip, drip) to flow to that wheel when bleeding. The other “functional” lines flow fast, almost like a faucet. So, I was also starting to wonder if I had an internally failed brake hose to the right rear causing the slow/minimal flow on bleeding. I didn’t. I don’t understand why Techstream does not resume proper flow to a corner, when you have told it specifically that you are bleeding the system? Why should I have to manually clear the DTCs? Not logical from my perspective.
  8. ChapmanF
    18,733
    I think the answer I'll go with is the people who wrote the brake ECU firmware and the people who wrote Techstream were not the same people, and nobody told them "hey, meet up together and take all the time and budget you need to devise the most awesome possible UX for bleeding the brakes."
    So the people who wrote the firmware wrote it to valve off leaky lines, which can be reset by clearing the codes. They also implemented the various subtasks that Techstream has to invoke in sequence to get the brakes bled. And if the topic came up, "whaddaya do to bleed the brakes if a line is valved off because of a leak?", and the question was "is there a way to do it?", the answer was "sure, the line isolation can already be reset by clearing the codes", and that was good enough.
  9. mr_guy_mann
    4,104
    2,006
    NJ-USA
    Techstream and Toyota's diagnostic information were designed and written with the basic assumption that the only people who would be using them were TRAINED automotive technicians.
    I don't think they had much consideration for the DIY crowd.
  10. Mendel Leisk
    42,058
    Or even independent professionals.
