Help?!! Alarm went off and dashboard lights flashing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by se7enbaes, Mar 1, 2017.
  1. se7enbaes
    se7enbaes Junior Member
    TX
    The alarm on my car went off and was going off for about 30 minutes. When I learned about it and tried to disable it with the key fob, it didn't work. I used the manual key to enter the car and discard the alarm by turning on the car. All the lights on the dashboard flashed, including the red triangle. The red triangle light went off and then just the engine, ABS, and the direction lights and a few others continued flashing. When I turned off the car and tried to exit, the warning beeping sound went off. I don't know what's going on. Any insight would be very helpful. Thanks! Here's a link to the short vid I recorded of the dashboard:
  2. JC91006
    16,482
    8,399
    You should check your 12v battery to make sure it's not low
    49,463
    what kind of car is it?
    'LectroFuel likes this.
