HELP...ASAP...Prius will not enter “invalid mode”
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Jul 20, 2019.
  1. qdllc
    qdllc Senior Member
    1,371
    399
    Last time I flushed the brake system, I used invalid mode and it worked fine. I can’t get it to do it now, and I’m at wit’s end.
    Set parking brake.
    Press POWER button twice (no foot on brake).
    Press brake and shift to Neutral (not that you have a choice).
    Press brake 8 times in 5 seconds.
    Switch to Park.
    Do the brake thing again.
    Press brake and shift to Neutral.
    Switch to Park.
    Some lists say to press more than 8 times in 5 seconds. I’ve tried holding the brake during all shifts (rather than just pressing Park).
    I desperately need help ASAP.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Watch the @NutzAboutBolts video in the 3rd gen maintenance section on the brake bleeding as he shows how to do it;).
    Good luck (y).
    #2 Raytheeagle, Jul 20, 2019
    NutzAboutBolts and Rebound like this.
  3. qdllc
    qdllc Senior Member
    1,371
    399
    I’m following that exactly and it’s not working. :(
  4. Leadfoot J. McCoalroller
    7,847
    7,314
    Pennsylvania
    2018 Prius c
    Brake lamp switch working okay?
  5. qdllc
    qdllc Senior Member
    1,371
    399
    Yes. I can see it reflecting off the garage door. Possible I’m pressing the peddle too fast?
    I can see the taillights flashing on and off.
  6. qdllc
    qdllc Senior Member
    1,371
    399
    It finally worked. I had siphoned off the master reservoir before starting. I filled it up and then it worked.
    Raytheeagle and Rebound like this.
  7. Leadfoot J. McCoalroller
    7,847
    7,314
    Pennsylvania
    2018 Prius c
    Is there a level switch in the reservoir? maybe that’s another element in the mode interlock?
  8. qdllc
    qdllc Senior Member
    1,371
    399
    I only thought to try that when the video showed siphoning off the reservoir after putting the Prius into invalid mode.
    Raytheeagle and Mendel Leisk like this.
