Help!!! Battery red (2-bars)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdustie, May 20, 2011.
  1. jdustie
    jdustie New Member
    revere
    I have a 2005 Prius 37000mi.
    Sister purchased brand new Norwood, MA.
    I was stuck in traffic for 20-25 minutes and the battery went from
    green (7-bars) to red (2-bars). The car was left to me a few days ago.
    A family member passed on.
    Am I looking at the 12volt bat or the main bat in the display ?
    Is this normal behavior ?
    I drove car for couple of hours (Boston to New Hampshire to charge
    battery and buy cigs) . The next day the same thing happened.
    The battery went from 7-Bars to 3-bars while stuck in traffic for
    15-20 minutes.
    Is it possible I need to replace HV battery ?
    thankyou, jdustie
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Good news! This is perfectly normal. The good news is that for 25 minutes you 'idled' without using any gas, now once it gets to two bars it will idle using some gas. But still less than cars that idle continuously. (The big screen is watching the HV Battery, the 12 volt battery is a lot shyer)
    By the way,[​IMG] to Prius Chat!
  3. N8JC
    N8JC New Member
    27
    32
    Minneapolis, MN
    First, the battery display is your main battery (a.k.a traction battery) not your 12V battery. Second, you Prius is operating as it should be. Enjoy!
  4. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I've never gone down to 2 bars/red, but I imagine it's normal in heavy traffic when the ICE never engages. ?
  5. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Yup and on long steep grades. Drive to Reno on i80 in the winter at 70+ mph and you'll see red bars. lol
  6. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    jdustie, I was stuck a couple days back in what was likely the same sort of Boston traffic. I was crawling for a half hour, and even doing everything I could (neutral under 7 mph, occasionally running engine very lightly to get most possible charge to battery, monitoring energy on Scangauge), my bars went down almost to that level.
    It's perfectly normal in situations like that where you're basically using electric only for miles and miles. The car will self-correct when you drive more with the engine on. You can help some by accelerating only as much as needed and quite lightly in electric. After the acceleration, lift your foot slightly from the accelerator (but still pushed down slightly) so the car continues to glide but there are no arrows on the "Energy" display of your display screen. Avoid jerky accelerations. If you're over 7 mph brake lightly and gradually to maximize regenerative braking.
    Lightly turning on the engine with the accelerator for a little bit can be good, too, just every now and then. Despite the low mpgs, when barely using the gas engine like that it'll charge the battery more rapidly than "normal" acceleration, help stop the bleeding a bit.
  7. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    The HV battery gauge on the MFD just gives you some reference. Not the exact amount in your HV bttery pack. Even when all bars gone, it still have 20% of charge there, No need to be panic when you see the bars in red color. Enjoy the color. On the other hand when it shows all bars green the battery pack is just 80% full. To prevent it from over charged, ICE may sometimes runs to discharge/reduce the capacity of the battery pack to keep it long life.
  8. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    Apparently they changed the color of the battery low charge bars from red to purple in the 2009. Interesting-
  9. richard schumacher
    7,663
    1,038
    United States
    It's completely normal and you don't have to do a thing. The car takes care of itself without any help.
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    IIRC, on my 06, if I'm down to 2 bars, it's purple. And yes, it's normal, esp. if you're stuck in stop and go.
    If you want to deplete it even quicker, turn on the AC, esp. w/the fan at the max in very hot weather.
  11. Patrick Wong
    18,200
    6,464
    I recently drove my 2004 south on Hwy 395 in California from Lake Tahoe to Bishop. That route covers highly mountainous terrain and the SOC indicator went from 8 green bars to 1 red (or purple, whatever) bar several times during that journey. A very good way to stress the traction battery.
  12. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Completely normal.
    The hybrid battery of the Prius is really not all that hefty - that is to say, it's not a Leaf or a Tesla with 100+ miles of range. Those 15 - 20 minutes of creeping in traffic (along with keeping the car powered) were enough to lower the battery state of charge.
    When the battery gets low, the engine kicks on to generate some more charge. This is normal. The car is fully capable of taking care of itself.
    A word, though. Every time you drive into that same situation, you will see the exact same behavior. You might hate it but you can't avoid it.
  13. bisco
    49,098
    and don't smoke in the car, it's bad for the battery. not to mention your lungs.
  14. jdustie
    jdustie New Member
    revere
    Thankyou all for your feedback.
    I feel much better this morning knowing that this is normal.
    thanks again, jdustie
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Some one mapped the SOC to what the MFD displays at Prius Palm Mileage Simulator.
    Yep. To also add to this, the OP probably noticed that when the HV battery got low, besides the above, the ICE would also sometimes turn on when accelerating (while creeping along) and shut right back down upon letting off the accelerator. This is also normal.
  16. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    if you are stuck in crawling traffic, or stop and go, AND running the radio, AC and fan on high...
    the battery will deplete quite quickly. it is normal.
    if you turn off the AC and the fan, and jsut open a window, you can stay fresh and battery will not go down so quick.
    close windows and use fan or Ac when traffic start to move again!
    AC and fan will also kill your MPG's
