Help! Brake System Problem
Discussion in 'Gen 3 Prius Technical Discussion' started by Redpoint5, Sep 15, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,024
    506
    Portland, OR
    I just started my PiP after fully charging it, hooked up a small trailer and plugged in the pigtail. Then I moved the car 200 ft along the curb and parked. Realizing that I need to move forward a few more feet, I attempted to start the vehicle, but the brake pedal travels all the way to the floor, I have a traction control error, and the display says I need to depress the brake pedal to start.
    The brake booster is making noise letting me know it's building up pressure, but the pedal travels to the floor. Brake fluid is right near the max, and nothing has been done to introduce air into the system.
    What could be the cause of the braking system failure? I'm hoping to leave in 2 hours, so I hope to get to the bottom of this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Did your car have the brake booster pump recall?
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    302
    Tropical Buffalo NY
    Four Touring
    Disconnect the trailer light connector , look for a blown brake fuse.
    bisco and Redpoint5 like this.
  4. Redpoint5
    1,024
    506
    Portland, OR
    That was all it was. Thought the fuse was good because I checked the rear light fuse, but the one that was blown said brake on it. Not sure if that is the fuse for the brake system, or for the brake lights. I'll check for shorts in the trailer tomorrow.
    The Traction Control light is still illuminated, so the car isn't entirely happy yet. Regen is still working correctly though, and normally it doesn't work when the traction control light is on.
