Help: Braking distance and ABS Skid Marks
Discussion in 'Gen 3 Prius Technical Discussion' started by PriQ, Mar 2, 2010.
  1. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Sounds like the OP crashed and wants to blame it on Toyota, and is seeking out people on here to help them. I would be willing to listen if they were warning us about their car not working right causing a crash and to help others. But it seems that they are trying to find ways to blame the prius.
  2. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    So ABS leaves no skid marks? That confirms my assumptions and previous experience.
    I am still awaiting a call from my insurance agency and Toyota. I will try to contact both Monday. If they allow, I will give you the details of the accident.
  3. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    This is exactly why the only thing I'm doing right now is asking about how the Prius should react under these circumstances. I ask a question, hoping to get a better insight to what has happened. It is as simple as that right now. Please don't read anything more into it.
    I don't want to raise an alarm should it turn out that it's simply me who has forgotten everything about braking distances or driven in a way that has damaged my brakes.
    My insurance covers the accident, so I don't have anything at stake (apart from the negligible deductible)
  4. adamace1
    1,403
    193
    Charlotte, NC
    Fair enuff. I hope everyone is ok.
  5. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    Here is what happened.
    I was going 35 (according to the police report. My own estimate is 35 to 40) and had to exit the road I was going on. The exit was a sharp corner, and I wanted to slow down to about 15.
    I applied the brakes with enough pressure to engage the ABS brakes, but instead of slowing down as I expected, the tires started screeching. This made me go fully on the brakes, but the car didn't slow down as expected and I crashed.
    - The car left a 65ft long skid mark, but only for the left front tire. The skid mark for the right tire is on 5ft long. Both skid marks are clear and continuous.
    - The investigator estimated that my first impact was with 20mph (after the 65ft of skid mark).
    - The ABS never engaged.
    - The car (1 month old 2010 Prius) was carrying nothing but me and some spare clothes.
    I am supposed to get the car back in a couple of weeks. The brakes will remain untouched, so I will take it for some brake testing. If I can recreate the brake failure, then I will take it in. If not, I guess it's all fine, but I will probably keep driving as if the brakes could fail.
    I have a bad feeling that the brakes might have gone bad because I have been using the regen brakes pretty much exclusively since I got the car.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Thanks for the update. No doubt in my mind that that brakes malfunctioned and I would have them looked at immediately from the information you gave.
    Now whether you entered that turn too fast... that is another story.
  7. bwilson4web
    16,549
    One lesson learned is to make sure and test your ABS when you first take delivery of the car. The other is to periodically 'wipe the rust' off the rotors with braking in "N" ... thanks to Hobbit for this earlier suggestion. I have noticed the 'rusty' sound after a day or so of rain but hadn't noticed it since A0B ... not that I was looking for it.
  8. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    Just a thought, but it's possible the skid mark, especially only on one tire, could reflect side-slip of the tire versus true rotational "lock up" especially if you were trying to make a sharp turn at high speeds.
    Also, next time you get a chance, make sure you can experience the feel of ABS in action - I read that the Prius ABS feedback is softer than most cars. When I pick up my Prius, that's one of the first things I plan on doing - find a large parking lot and see how it handles on emergency stops so I have a better feeling of when is "too close" really "too close".
  9. cc_prius
    cc_prius New Member
    39
    Tracy, CA
    That explanation makes the most sense to explain the skid primarily on only the front left tire as the weight shifting to the left would reduce the traction of the right tire. Does anyone know how the VSC should react to this situation?
  10. fuzzy1
    10,721
    I think I'd have the brakes and brake controls checked out right away, before trying to recreate anything, especially in case there are any stored codes that could be cleared after a certain number of restarts.
    Other readers -- why would rotors rusty from disuse cause ABS problems? My other car is very susceptible to rusty rotors and rust pitting, partly because I've long practiced what hypermilers call 'driving without brakes', and partly because it isn't my daily driver. And it just seems susceptible to rust. While this rust does demand more brake pressure for ordinary light braking, I've never had hard braking or ABS problems with it.
  11. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    I don't know about you guys, but why would you want the ABS to engage purposely to slow down a car for the corner?
  12. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    It makes sense that the marks might have been from sideways slip. The mark is straight almost till the end (where the second mark starts), and I didn't try turning before I knew it would be a close call. I might still have upset the balance in some way, forcing the weight onto the left tire before braking.
    I will try all this once I get the car back (and out huge parking lot is empty).
    Thanks.
  13. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    That is what I wanted, but Toyota could first send out their professional in a couple of months, and in the meantime I would be without a car (My iQ is on another continent). The insurance agency has sent our their investigator, but I have not been told what they found, which is why I will test the brakes for myself (in a safe place) once I get the car back from the repair shop.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What was the extent of the damage?
  15. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    That is awful that it will take Toyota a couple of months to look at your brakes. Can you post a picture of the skid marks? I'm just curious.
    Good luck with your car.
  16. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    Cosmetic + realignment. Toyota has made a smart choice and place all vital parts behind the huge cross beam behind the bumper, so I only need to get panels, lights and sprinkler fluid canister replaced.
    As for a picture, the sun made it hard to get a good one of the skid marks. I have this showing the entry to the curve (notice how the long left one is straight)
  17. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    I'm sorry, I don't mean for this to sound harsh but it sounds as if you were just going too fast for road conditions, lost control and are needing to get out of a ticket. You admit you tried to activate the antilocks but if you hit something loose (gravel, etc) then there's only so much they can do ~ they cant overcome physics.
    As for rust on rotors, it's a a common condition especially on higher end cars and it only makes the brakes a bit grabby for the first activation or two.
    Again, no disprespect intended but it just doesn't sound like a problem with the Prius.
  18. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    I was obviously going too fast...
    but didn't get a ticket. Should I?
    I just want to know how I could suddenly completely misjudge the braking distance on a fine dry road going at a relatively low speed. If I messed up the balance of the car or caused the brakes to be in a poor condition, then I want to know so that I can prepare for it in the future.
  19. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    Maybe your previous car had a bit more of a sporting nature than the Prius (it just about had to) and a bit more grip? Maybe it had better tires (again, it almost had to)?
    I pushed my car a bit hard around a couple of corners and found it's a lot easier to upset than the previous car I had and that was no sports car either, believe me.
    The little skinny tires we have to have in order to get great mileage sure cost us in the handling department.
  20. austingreen
    13,714
    4,232
    Austin, TX, USA
    Skid marks indicate that there is a problem with the car.
    It would be nice if technical details were analyzed instead of posters motives. On the braking software issue, posters jumped to the "physics defense" without trying to understand what the are was doing, or if it should be doing that.
