Help: Braking distance and ABS Skid Marks
Discussion in 'Gen 3 Prius Technical Discussion' started by PriQ, Mar 2, 2010.
  1. dzaky
    dzaky New Member
    UK
    Dr Donghyun Kim has simulated the VSC operation in 'Estima hybrid' during cornering as in the attached file.
  2. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Well,
    In our Prius V Advanced Technology Package, while going 50mph (while no one was around) I stood on the brake and it didn't skid. I herd maybe one chirp from the wheels, but thats about it. It is very responsive too, and one thing I noticed that when I hit the brakes really hard, there's like, a motor in the seatbelt chamber that pulls your seatbelt up if it thinks a crash is unavoidable (or so I guess) it feels like its choking the s*!& out of you for a second haha! But it stops very smooth, and fast.
  3. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    It has been a while. I might soon get my Prius back, so that I can find out what happened.
    My other car is a Toyota iQ. My iQ is slightly overpowered, extremely short and resides in a country with higher speed limits, tricky roads and lots of snow, so I made sure to get familiar with the limits of that car - including when the traction control and ABS kicks in.
    With the low speed, long safety distances between cars and general laid back behavior, I didn't spend time on finding the limits of my Prius. This was obviously a huge mistake, which I will make up for once I get it back.
    You say the tires aren't very good. They appear to be the same width as on my iQ, but the Prius weight much more. The Michelin tires on the iQ are quite good. Is the same not true for the standard Prius tires?
    Thanks. I don't know what he means with "no control", but I will see if I can find his own writeup.
    Thanks a lot. It sound like the ABS works quite smoothly in the Prius, and the car should stop rather abrutly as you mention. I suppose the seatbelt motor works a bit smarter with your AT package than in my Prius IV.
    As promised, I will take my Prius out on a huge empty parking lot, bribe the security guard and abuse the car until the brakes fade, tires wear out or I hit another lamp post.
  4. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Go find a local autox and give it a shot
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A long straight skid mark indicates the car has lost steering ability and is just sliding. So ABS is not functioning.
    If you just "lock up" the front wheels and slide them a bit sideways VSC won't engage. It needs to see the rear start to come around before it works.
    There have been reports that on loose surfaces ABS (not a Prius) can lock up one wheel and cause a crash. This was with GM SUVs and trucks. Was there anything like sand on the road?
    Rust on the rotors shouldn't cause something like this unless it caused grabbing of the one brake. But the ABS -should- have compensated. Unless it was extreme and the ABS did release the one brake but it was still jammed by the rust. That might explain the other wheel eventually locking (the ABS trying to compensate). But that is all speculation.
    I have never intentionally tried to "clean the rust off the rotors" in my GII Prius and I have never experienced brake grabbing or any other brake event (other than the brake release over rough bumps).
    Any way to tell if it was a front wheel lockup or a rear (tire flatspot for example)?
  6. cossie1600
    903
    94
    CT
    If you lock up a rear tire, chances are that you will spin and take out something good
  7. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    I have my car back now. It has been repaired, but the brakes are untouched.
    Since it's Memorial Day, the parking lots at work are empty - so it was time to test. Here are the results.
    ABS:
    The ABS doesn't make the noise as in other cars. Actually, you can hardly feel it. It pretty much feels like braking a car without ABS. I have attached a couple of pictures. The skid marks are solid and there are two of them. I simply performed the standard "brake as hard as you can" routine from different speeds. The pictures show the result from 45MPH.
    VSC:
    The car starts skidding when cornering long before VSC kicks in - I have still not been able to make it go off, but will try again later if I find a place with a larger plain area. Right now I can say that the Prius actually corners pretty well, as long as you don't do it while braking hard (see below)
    Off balance braking:
    Stuff goes bad if you happen to throw the car off balance (such as with a sudden directional change) before braking. When the weight is biased to one side, the car had a very hard time transferring brake power to the other side. Again. I couldn't get VSC to engage while doing this. This basically forces one tire to do all the work. This seems to be more of a problem with the Prius than other cars I have driven, due to the thin tires.
    This is most likely what happened to me when I crashed.
    In conclusion.
    You don't feel the ABS, but the car still brakes really well, as long as you allow all tires to actually have grip. If you ever brake while being off balance, simply counter steer a little more than what you would do in another car.
